brake wear indicator, outside or inside?
kaitanium
Anyone know if the brake wear indicator on brake pads should be on the inside or outside of the caliper? Doesnt sound like it would matter or make a huge deal in terms of safety? Doesnt hit the rim if installed on the outside.
Inside, because the LGT's brakes are single piston which push from the inside, so you will see slightly faster wear on the inside. I'm not sure the squealer will even fit on the outside. I run Carbotech Bobcats, which don't have a BWI, so I have to check them visually:( On the bright side they're easy to rotate if I'm feeling cheap!
