fiber_tek Posted August 15, 2011 Share Posted August 15, 2011 I did a search for "door locks" and didn't come up with anything related to my problem. The power door locks seem to be getting a mind of their own. If I shut the door a little too hard it will lock all the doors. The driver's side switch is getting REALLY touchy. Does this need to be replaced or just cleaned? Jason Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 15, 2011 I Donated Share Posted August 15, 2011 Probably just cleaned. Get some electrical contact cleaner and clean them out...or you can use rubbing alcohol. Do you by chance have an aftermarket alarm system? -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
fiber_tek Posted August 17, 2011 Author Share Posted August 17, 2011 I'll give that a shot, thanks for the help. Jason Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 18, 2011 I Donated Share Posted August 18, 2011 No problem Jason -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Stefan9876543 Posted May 14, 2012 Share Posted May 14, 2012 I'm having this same problem, but it's gotten really bad. Sometimes I just can't get in the back doors because they're constantly locking. As I drive down the road they will just lock and relock and relock over and over again. So the solution is cleaning the sensor? Do I need to take off the door panel to do this? Specifically what do I need to clean? Thanks, Stefan Link to comment Share on other sites More sharing options...
Kennyfvholla Posted May 15, 2012 Share Posted May 15, 2012 Yes, take the door panel off. The 97 and ealier cars have a central locking system that is controled by the drivers lock/unlock switch. It is conected to a rod which is connected to the power lock modual by a few different parts. It looks like this http://i41.tinypic.com/2pyce52.jpg Check to make sure that everything is in working order and not broken. The contact for the system is inside of the black door lock actuator. You can take it apart with a few phillips screw drivers. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 15, 2012 I Donated Share Posted May 15, 2012 Stop feeding your door locks crack. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
LegacyLou Posted May 16, 2012 Share Posted May 16, 2012 Do you by chance have an aftermarket alarm system? After my alarm/ remote start was installed the driver door would not lock or unlock with the lock button. What do I need to look at to fix this John. Link to comment Share on other sites More sharing options...
monkeyposeur Posted May 17, 2012 Share Posted May 17, 2012 Use the force. And silicone spray. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 17, 2012 Share Posted May 17, 2012 both my lock switches done work on each door. is there a fuse for that? the last owner lost the fuse cover so i have no clue. BNR18g on 93oct Link to comment Share on other sites More sharing options...
