PaulieKeyboard Posted January 18, 2011 Share Posted January 18, 2011 So any one have any suggestions or words of wisdom for removing broken exhaust studs? I'm trying the normal pair of vice grips, PB blaster and propane torch but all I seem to be doing so far is just f*ing it up and not getting it to turn at all....any other ideas that have worked for anyone? Link to comment Share on other sites More sharing options...
KuNomn Posted January 18, 2011 Share Posted January 18, 2011 PB blaster and the middle plier here did the trick for me http://www.musclecars.net/parts/parts-images-large/snap-on-tools-pliers-adjustable-wrench-pliers-pwz2-ap12_330508525519.jpg Link to comment Share on other sites More sharing options...
Osei Posted January 20, 2011 Share Posted January 20, 2011 If the vise grips and PB doesn't work, go to Autozone or Advance auto/or similar and get an Irwin stud exxtractor. You have to generally pay for the set (you only need the 10mm one) and get a refund when you return. Pound it on with a hammer and use a3/8 drive bar to turn it. Don't use a ratchet, use a breaker or T bar. Use a 1/2 to 3/8 adapter if needed. That will work. O. Link to comment Share on other sites More sharing options...
PaulieKeyboard Posted January 21, 2011 Author Share Posted January 21, 2011 Unfortunately the 10mm was too by bc I marred up the stud with the vice grips...the 8pm didn't seem to be able to grab...any other ideas? Link to comment Share on other sites More sharing options...
mwiener2 Posted January 21, 2011 Share Posted January 21, 2011 You could do what I had to do today.... Take the hot side off the turbo and take it to a machine shop to have the holes drilled out. I spent an hour with a drill and cobalt bits and only dimpled the bolt. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Osei Posted January 21, 2011 Share Posted January 21, 2011 Unfortunately the 10mm was too by bc I marred up the stud with the vice grips...the 8pm didn't seem to be able to grab...any other ideas? If the 10mm won't fit. it seems highly unlikely that the 8mm won't. It is supposed to be a very tight fit. The 8 should not go on unless you bang it on with a hammer. I didn't turn the head bolts loose properly and had to use one to get it off. At least 80 ft lbs of torque. No reason why it shouldn't remove an exhaust bolt. O. Link to comment Share on other sites More sharing options...
fiber_tek Posted January 22, 2011 Share Posted January 22, 2011 Use a torch and get the area heated up and then spray it with WD-40, the heat will pull it in to the threads. Then use an EZ-Out with a drill and it will come out. It may take more than one shot with the heat and WD-40, but it works. Link to comment Share on other sites More sharing options...
DN1911 Posted January 25, 2011 Share Posted January 25, 2011 may just have to drill the bolt most of the way out. just make sure your straight! can also try welding a nut to the end of it depending on access to tools Link to comment Share on other sites More sharing options...
