bengt Posted March 15, 2014 Share Posted March 15, 2014 Hi, I'm curious if a 2005 wrx wagon steering rack will fit in my 98 LGT wagon with a 90-94 turbo legacy engine crossmember. I've heard everything is fine up until 05 and won't fit after, but wondering if anyone has any experience or knowledge on this. Thank you. Link to comment Share on other sites More sharing options...
subikid90 Posted March 17, 2014 Share Posted March 17, 2014 You will need the 05+ wrx cross member to make the rack fit. I did this swap in my car -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
boattlebot Posted March 17, 2014 Share Posted March 17, 2014 is thier any benifit to a wrx rack? just wonderin Link to comment Share on other sites More sharing options...
subikid90 Posted March 18, 2014 Share Posted March 18, 2014 Yes it has a shorter turn radius then the LGT and way shorter radius then the outback. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
boattlebot Posted March 18, 2014 Share Posted March 18, 2014 cool Link to comment Share on other sites More sharing options...
bengt Posted March 18, 2014 Author Share Posted March 18, 2014 Bummer! Does the stock rag joint fit into the 05 rack? Or do you have to change that too? Link to comment Share on other sites More sharing options...
98 OB RNV Posted March 18, 2014 Share Posted March 18, 2014 I guess if I went through this much of a process it would be a little more justification to actually put a WRX engine in it. Link to comment Share on other sites More sharing options...
bengt Posted March 19, 2014 Author Share Posted March 19, 2014 I guess if I went through this much of a process it would be a little more justification to actually put a WRX engine in it. It's got one in it Link to comment Share on other sites More sharing options...
bengt Posted March 22, 2014 Author Share Posted March 22, 2014 Well I got it installed. Super easy actually. The 05 rack is the new style mounting, where the drivers side mounts through the rack and not with a bracket like the passenger side. All the holes lined right up and were perfect. Only problem was the input shaft that the rag joint connects too is a bit bigger around and a different spline. I tooK apart the rack side of the rag joint and installed a lower coupler with the correct spline so I had old on the top at the colomn and new on the bottom at the rack and it went real smooth. Such a great upgrade, should have done it long ago. Link to comment Share on other sites More sharing options...
vr4 Posted March 22, 2014 Share Posted March 22, 2014 Bolted in using your original subframe or the 05 subframe? Link to comment Share on other sites More sharing options...
bengt Posted March 23, 2014 Author Share Posted March 23, 2014 Bolted in using your original subframe or the 05 subframe? Using a 90-94 turbo legacy crossmember. Link to comment Share on other sites More sharing options...
vr4 Posted March 23, 2014 Share Posted March 23, 2014 Damn that doesn't help me but at least opens up options. Thanks Link to comment Share on other sites More sharing options...
bengt Posted March 23, 2014 Author Share Posted March 23, 2014 No problem. Well since it fits the old I would venture to assume you could make it work in just about everything Link to comment Share on other sites More sharing options...
