grmorrow04 Posted August 31, 2010 Share Posted August 31, 2010 I can't seem to really see anything available except Cusco camber plates. What plates are available (front/rear - not camber plates for the rear, just pillow ball plate)? Thinking about some AST4100's a local Suby shop is going to be offering on a price-point that's on par with the Tarmac's. Link to comment Share on other sites More sharing options...
m sprank Posted August 31, 2010 Share Posted August 31, 2010 AST generally uses Vorschlag plates. There are lots of options (including Vorsch and GTWorx). The AST4100's are about $1650 for just the strut. I know because I just bought them. They are in no way on price point with Tarmacs. I sold my Tarmacs to build the AST set up. With AST you only get the strut. You have to tell them what spring rate (so they can valve it), then supply your own springs, tophats and assembly. I orderd mine from RCE. Myles is assembling them with 600/650 Swift springs and Vorsch plates. Complete package assembled is in the $3150+ range. Link to comment Share on other sites More sharing options...
Saul_Good Posted August 31, 2010 Share Posted August 31, 2010 Whiteline has camber plates. THey're listed for the 08+ WRX which should have identical strut mounts to the LGT. If i didnt already have the cusco plates, i'd have these instead. They're both camber/caster adjustable. http://www.aqmotorsports.com/whiteline-maxc-strut-mounts-adjustable-pi-2294.html?invis=0 Link to comment Share on other sites More sharing options...
grmorrow04 Posted August 31, 2010 Author Share Posted August 31, 2010 AST generally uses Vorschlag plates. There are lots of options (including Vorsch and GTWorx). The AST4100's are about $1650 for just the strut. I know because I just bought them. They are in no way on price point with Tarmacs. I sold my Tarmacs to build the AST set up. With AST you only get the strut. You have to tell them what spring rate (so they can valve it), then supply your own springs, tophats and assembly. I orderd mine from RCE. Myles is assembling them with 600/650 Swift springs and Vorsch plates. Complete package assembled is in the $3150+ range. Not saying I doubt you at all, especially since I enjoy reading/analyzing your posts here, but I wanted to call and verify what I was told this weekend. Product - AST4100 Price - $1650 Order includes - Struts, springs (of my chosing), helper/tender springs, adjustment tools What's not included - camber plates (hence the reason for this thread ) Granted, I haven't placed an order yet, but I don't think the information I was given will be changing anytime soon. Link to comment Share on other sites More sharing options...
m sprank Posted August 31, 2010 Share Posted August 31, 2010 If that is correct you are getting the springs for free. Which is an amazing deal. From the AST USA website; http://www.ast-usa.com/ast-4100-shock-absorber-coilover-kit.php Benefits include: Monotube design - gives the biggest piston sizes availableFloating piston design with high pressure nitrogen means no cavitation around the pistonAdjuster knobs permanently mounted on the dampers – no fumbling for knobsFully threaded strut bodies allow maximum tire width without fender rolling or larger spacersRebuildable by AST-USA – get the valving you want, when you want it. Pricing starts at $1650 for struts and shocks (without springs) AST-USA provides a 12 month warranty on the 4100 Series shocks and dampers. » Rebound Adjustable ("Singles") » 22mm diameter shaft struts, non-inverted » Steel cylinder body shocks, non-inverted » Rubber bushings for "eye" shock mounts » Optional spherical upper shock mount assemblies » Non-synthetic hydraulic fluid Might want to triple check that someone is not mistaken. Otherwise stick it to them and make them give you the most expensive springs you can find for free. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted September 2, 2010 Share Posted September 2, 2010 I have the DMS camber - camber/caster plates. They are pretty cool! Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
m sprank Posted September 2, 2010 Share Posted September 2, 2010 ^ They look amazing in the pix. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted September 2, 2010 Share Posted September 2, 2010 ^ They look amazing in the pix. Easy to adjust too, and very very repeatable: http://finelineimports.net/images/_dms_front_camber_plates_WRX_2.jpg Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
