Rear Caliper Guide Pin Boots
Where do you guys get the rear caliper guide pin boots? I've tried a few different aftermarket brands and they all seem to be way too small, maybe from 2.5i or previous gen Legacies.
04+ FXT's have the same sized ones as the Legacy GT, but the aftermarket part numbers show the same wrong part too.
Aftermarket on left, stock one on right, see the difference:
http://legacygt.com/forums/attachment.php?attachmentid=259478&stc=1&d=1513132252
05 LGT 16G 14psi 290whp/30mpg (SOLD)
12 OBP Stock 130whp/27mpg@87 Oct
00 G20t GT28r 10psi 250whp/36mpg
22 Ascent STOCK
The dealer. But I think you need to buy them in a kit. Call the guy's at Fredbeans.
Have you tried NAPA ?
Sadly I think most will only sell as a kit. I couldn't find anything on their website though.
Will try Napa, I also will try autozone with a 2008 2.5i part number (it showed up as different part # then the wrong ones).
They come in kit #26697FC000, MSRP $29.05. The kit also includes a piston o-ring, boot, slider pin o-ring, and grease.
Yup that's what the dealer quoted me, at that price I would just buy a new remaned caliper for $50 :lol:.
Are you able to get the boots only by any chance?
22 Ascent STOCK
Did more digging, looks like the GT Legacies do have different rear brakes compared to the rest. GT's have ventilated rear brakes, while the rest are solid.
This can be really seen on these diagrams: http://opposedforces.com/parts/legacy/us_b13/type_7/brake_system/rear_brake/
Ventilated rotor caliper rebuild kit is 26697FC000
Solid rotor caliper rebuild kit is 26697FC000
22 Ascent STOCK
It seems like rears are too. Every store made it seem like GT was the same as 2.5i's for the rears, but checking OpposedForces I finally see a difference.
Also centric part numbers for rotors are different for GT vs 2.5i.
GT: 12047025 - 17.90mm nominal thickness
2.5i: 12047026 - 10.00mm nominal thickness
22 Ascent STOCK
Remember, there's a lot more labor when replacing the caliper instead of just the boot's.
Engine Build - Click Here
With 5+ engine swaps, 4+ custom turboed cars, 1 custom 6 speed rebuild/swap, replacing a caliper and bleeding it is cakewalk :lol:. Plus with 100k+ mile calipers, they start sticking anyway it's a much better investment to just buy a $50 reman. Plus rebuilding a caliper all of the way is much more difficult and still requires bleeding of brakes.
22 Ascent STOCK
One of my pistons on the front had a torn boot and it started sticking, that coupled with using the wrong grease on slider pins and bam locked up brakes. That's at 100k miles... My 04 FXT has 162k miles, while the calipers and pistons are much rustier, the boots still seem decent and the pistons still move freely which is really all that matters.
Next time you do your brakes, see how easily the piston goes back into the caliper, if it moves easily and your boot looks fine, I say run em till they lock up :).
22 Ascent STOCK
I play with my brakes once a year typically to paint them. The pistons all slide nicely. The piston boots are begining to show some age.
Do you have a set of the GT rear rotors from Centric? Are they ventilated like the OE rotors?
Thanks, I will need to get a set of those Centric rotors for the rear. My rear pads are wearing unevenly, and are leaving deposits on the rotors. My rear rotors look more worn than my front rotors. I must have frozen slider pins, or pistons, or calipers rusted onto the clips, or some combination of these!
The price is a little more palatable when you realize it contains enough parts to rebuild two calipers, not just one.
Uneven pad wear could be the stuck pin or bad brake hardware brackets.
Usually if the pad is uneven top to bottom, then it's probably the stuck pin. If it's uneven side to side, then it's the hardware.
O'RLY? That does change it a bit!
22 Ascent STOCK
My outside pads are more worn than the inner pads. Saw this in another thread:
"The rears tend to stick unless the retainer clips are lubricated. I lost one rear pad at 30k miles, and it was one with no wear sensor so my first hint was metal-to-metal grinding. My dealer's lead mechanic is master certified and says this problem is common and is due to the factory lubing the clips. You must use a thin coat of high-temperature grease so it doesn't burn off or migrate to the friction surfaces. I use Moly-Slide, a grease with 60% moly; a 1 oz tube costs ~$7 and lasts forever since you only use a little bit………………."
http://legacygt.com/forums/showthread.php/ridiculous-rear-brake-pads-wear-93720.html?highlight=pads
I bought some Dow Corning Molykote M77 grease to use on the pad clips. It is what Honda recommends for their disc brakes.
  • 3 months later...
Just an update, got the set from Underdog. They come with everything you need to rebuild the caliper too.
http://legacygt.com/forums/attachment.php?attachmentid=259479&stc=1&d=1513132309
22 Ascent STOCK
For anyone else interested partsouq.com does most genuine parts at a fair chunk cheaper than any dealers around. $13 for the same kit.
And items i've bought from there in the past for a JDM car actually come quicker than from subaru dealerships which seem to put all parts they don't have in stock on the super slow boat from japan.
https://partsouq.com/en/search/search?q=26697FC000
2000 Legacy B4 RSK - SOLD
2006 Legacy BP5 GT Spec B wagon - Garage Thread
2011 VW T5 van 2.0L of turbo diesel awesomeness
