covertrussian Posted March 2, 2014 Share Posted March 2, 2014 Does anyone know why Subaru decided to add restrictions to the oil drain? Seems really odd, you want this opening as big as possible to get all of the gunk and debris out. http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Engine/General/Oil%20Pan/2014030201.jpg~original http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Engine/General/Oil%20Pan/2014030202.jpg~original Edit I did an oil change with one of these oil pans and it was awful, oil just gushed everywhere instead of being one nice continues stream. Luckily mine has a quick drain, so it makes it into one friendly stream. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
rob-2 Posted March 3, 2014 Share Posted March 3, 2014 Silly subaru of course! Same reason the tranny filter is in the front fender. Or they left near zero room for spark plug changes. My list could go on Link to comment Share on other sites More sharing options...
Max Capacity Posted March 3, 2014 Share Posted March 3, 2014 Why that's a great idea, its a safety thing. They don't want the hot oil rushing out of there and possibly burning someone. Mankind should be greatful they are looking out for them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted March 3, 2014 Share Posted March 3, 2014 Why that's a great idea, its a safety thing. They don't want the hot oil rushing out of there and possibly burning someone. Mankind should be greatful they are looking out for them. You know it all my years I've never had that problem Link to comment Share on other sites More sharing options...
covertrussian Posted March 3, 2014 Author Share Posted March 3, 2014 Just like the banjo filters right? I've owned Nissan's all my life and while they had some stupid things here and there, I've never seen a continues stream of stupid. What sucks is we are trying to flush out an engine that went through two turbos already, found pieces of turbo bearing. in the oil pan as is. Thus doing a full oil flush wont do much good if they get stuck in the drain. But with all of the baffles you do run the risk of debris being stuck in those too, if only removing the oil pan was easier... Either way, when I replace my oil pickup I'm probably going to drill out/grind off the restriction on my car. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
Max Capacity Posted March 3, 2014 Share Posted March 3, 2014 You know it all my years I've never had that problem Obiously you don't work for a big industrial company. There are so many stupid things we do all in the name of safety. Most of them because someone did something stupid. Like the guy in WV that wanted to use a old 55 gallon solvant drum for a barbeque grill. He figured he use a plasma cutter to cut it in half...DUH, can you guess what happened ? We just got a re-fresher training today in a email... Or the women in CA that tried to push a 6ft tall cabinet which had power supplies in the top of it up a carpeted ramp in the office area, luckily one of them only got a broken leg out that... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
covertrussian Posted March 3, 2014 Author Share Posted March 3, 2014 Oil spits out just as badly as it does on my other non Subaru's... Not the best pic because the bolt is in place, but no safety net... http://images.rvsmods.com/var/albums/Cars/B15/Engine/SR20DET/Swap/CIMG8847.JPG?m=1345353826 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
Max Capacity Posted March 3, 2014 Share Posted March 3, 2014 Your going to put that in the hot tank next....correct? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
covertrussian Posted March 3, 2014 Author Share Posted March 3, 2014 That's just paint chipping, JDM SR20's are stored on their oil pans, when they ship it to you the oil pan is generally dented. Requires you to use a hammer to bend it back out. They are painted inside and out, thus after you work on it a little paint chips. Been running it for many years and it's fine, so not concerned about it. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
rob-2 Posted March 3, 2014 Share Posted March 3, 2014 Obiously you don't work for a big industrial company. There are so many stupid things we do all in the name of safety. Most of them because someone did something stupid. Like the guy in WV that wanted to use a old 55 gallon solvant drum for a barbeque grill. He figured he use a plasma cutter to cut it in half...DUH, can you guess what happened ? We just got a re-fresher training today in a email... Or the women in CA that tried to push a 6ft tall cabinet which had power supplies in the top of it up a carpeted ramp in the office area, luckily one of them only got a broken leg out that... I see the thread. Common sense, not so common. Still some of the design choices I've seen at subi seem to defy logic or maybe that was your point Link to comment Share on other sites More sharing options...
Strizzy Posted March 4, 2014 Share Posted March 4, 2014 The two oil pans I have laying around don't have that. My bad luck build Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 4, 2014 Share Posted March 4, 2014 OMG...One of your pistons is in your oil pan blocking off the drain......... Link to comment Share on other sites More sharing options...
Nrw Posted March 4, 2014 Share Posted March 4, 2014 The two oil pans I have laying around don't have that. 04-05 thing IIRC. Link to comment Share on other sites More sharing options...
Strizzy Posted March 4, 2014 Share Posted March 4, 2014 04-05 thing for the "cage" around the drain? My oil pans are newer, one being from my 08. My bad luck build Link to comment Share on other sites More sharing options...
Nrw Posted March 5, 2014 Share Posted March 5, 2014 04-05 thing for the "cage" around the drain? My oil pans are newer, one being from my 08. Yeah, Subaru redesigned the pan in 06. 04-05's also have a stupid bump that gets in the way of some headers. Link to comment Share on other sites More sharing options...
covertrussian Posted March 5, 2014 Author Share Posted March 5, 2014 I might just buy a new oil pan, mine is fairly rusty... 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 5, 2014 Share Posted March 5, 2014 Here's what I'm going to use on my build. It includes pick up tube too. Moroso PN 20965 billet aluminum 5 quart oil pan. http://autoplicity.com/masterimages/full/EBA/13/137128.jpg.ashx?maxwidth=328&maxheight=228 Link to comment Share on other sites More sharing options...
covertrussian Posted March 5, 2014 Author Share Posted March 5, 2014 Already got a pickup, not sure I want to spend another $500 on just the oil pan... 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
covertrussian Posted March 5, 2014 Author Share Posted March 5, 2014 Anyone have part number for the newer style oil pans? 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
kits gt limited Posted March 5, 2014 Share Posted March 5, 2014 Here's what I'm going to use on my build. It includes pick up tube too. Moroso PN 20965 billet aluminum 5 quart oil pan. http://autoplicity.com/masterimages/full/EBA/13/137128.jpg.ashx?maxwidth=328&maxheight=228 Unless you are going to track the car, no need for the Moroso pan. The baffles in place will keep the oil where its meant to be while in the corners to prevent starvation. Link to comment Share on other sites More sharing options...
rob-2 Posted March 6, 2014 Share Posted March 6, 2014 Unless you are going to track the car, no need for the Moroso pan. The baffles in place will keep the oil where its meant to be while in the corners to prevent starvation. I might be getting some starvation on the streets Link to comment Share on other sites More sharing options...
subiestang Posted March 6, 2014 Share Posted March 6, 2014 Yeah, Subaru redesigned the pan in 06. 04-05's also have a stupid bump that gets in the way of some headers. Actually there was a split in 05. The later ones have the 06 pan. Mine is a late 05 without the stupid cage. Subaru parts department calls it an '05 1/2. Link to comment Share on other sites More sharing options...
Nrw Posted March 26, 2014 Share Posted March 26, 2014 For anyone who is interested in the pan differences, 06 on the left 05 on the right. Link to comment Share on other sites More sharing options...
covertrussian Posted March 27, 2014 Author Share Posted March 27, 2014 Thanks, the new pan definitely looks cleaner, less baffles for crap to get stuck on. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
covertrussian Posted November 12, 2014 Author Share Posted November 12, 2014 Looks like the replacement oil pan is 11109AA151. Which is the same as the 06+ STI. Seeing this post, it seems like there is a baffle bolted to the block that might need to be replaced. I also am wondering if I will need a new oil stick and oil tube. Here is another thread with EJ20 vs Ej25 baffles and oil sticks comparision. EDIT: I called my local Subaru dealer and he said that for 05 it's 11109AA131, and 06 its 11109AA151. But he did say the oil pickup tubes are different and dipsticks are too. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
