Sir_vq Posted March 27, 2012 Share Posted March 27, 2012 i just purchashed the eibach pro-kit for my 08 3.0r, before i ordered them i checked in work usiing my VIN vs a SPEC B VIN. the spriings are the same, however the front sway bar is not so my question to those who have a 08-09 3.0r what front sway bar are you using in place of the OEM one,also what sway bar links are you using,thanks in advance Link to comment Share on other sites More sharing options...
bmx045 Posted March 27, 2012 Share Posted March 27, 2012 this is pretty much the only front and rear sway bar that will fit your car. turbo and n/a have diff front bars. rears are the same. i had these on my 09 2.5i: http://www.rallitek.com/RalliTEK-Anti-Sway-Bar-Kit-LegacyOutback-Non-Turbo-2005-2009/p-4363 links can be whatever you want Link to comment Share on other sites More sharing options...
crfnick56 Posted March 28, 2012 Share Posted March 28, 2012 I have been thinking of the same kit for my 3.0R but just want to clarify for sure that any legacy springs (2.5/GT/3.0R) will fit..... correct?? Link to comment Share on other sites More sharing options...
bmx045 Posted March 28, 2012 Share Posted March 28, 2012 All the suspensions are the same except for the front sway bar on gt Link to comment Share on other sites More sharing options...
Sir_vq Posted April 22, 2012 Author Share Posted April 22, 2012 this is pretty much the only front and rear sway bar that will fit your car. turbo and n/a have diff front bars. rears are the same. i had these on my 09 2.5i: http://www.rallitek.com/RalliTEK-Anti-Sway-Bar-Kit-LegacyOutback-Non-Turbo-2005-2009/p-4363 links can be whatever you want thanks, did you use the avo rear sway bar bracket with these or any other type of a/m bracket for the rear just concerned I'm hearing its a weak point Link to comment Share on other sites More sharing options...
bmx045 Posted April 22, 2012 Share Posted April 22, 2012 just the rear brackets. i used the avo adjustable endlinks Link to comment Share on other sites More sharing options...
