rahulkatti Posted July 31, 2009 Share Posted July 31, 2009 Hey guys, I have fallen in love with the sound of the hogzaust and am dying to make my car sound like that. one problem, the exhaust bolts wont budge cause of rust and as of this moment after 2 days of war, rust is winning. have tried wd-40, no good. just finished trying heavy artillery in the form of a powerful rust remover (PB Blaster), the bolts still wont budge. have broken a wrench head while trying (most probably due to my awesome strength) still, i feel this is pain and suffering before the awesome end result. please help me. my final battle takes place this sunday in which my weapon of choice is the blowtorch (or maybe a saw just to cut them) though i have never used one before in my life. have any of you successful hogzaust modders had the problem i am facing. can you please suggest a solution other than the ones i have mentioned thanks in advance Long live the Hogzaust! Link to comment Share on other sites More sharing options...
skiskank Posted July 31, 2009 Share Posted July 31, 2009 PB Blaster Link to comment Share on other sites More sharing options...
Throttlejockey Posted July 31, 2009 Share Posted July 31, 2009 Ahh, the sound of an exhaust leak.... PB Blaster and an impact wrench. Link to comment Share on other sites More sharing options...
Gire Posted July 31, 2009 Share Posted July 31, 2009 Good luck, and yes, the correct tools are in order. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 31, 2009 Share Posted July 31, 2009 When do you live ? May be some one is close to you and can help. Sounds like you don't have good tools. A 1/2 ratchet and good 14mm socket and box end wrench is all you need. A piece of pipe on the end of the ratchet may help. Buy Sears tools. There the best for the backyard mechanic. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
hogmeat Posted July 31, 2009 Share Posted July 31, 2009 Agree with impact wrench, unless you don't have access or need to have even an electric one handy in the garage. Worst case, get a dremel and some of the big cutoff wheels, and cut the nut off. Or, if you have two 14mm endwrenches, but put pipe on each one, and twist so hard you snap the bolt. It's just a plain old bolt, so snapping is no problem. You need to have 2 wrenches, so you put all the force on the bolt, not the actual piping itself. Other than that, torch works too Keep me posted!! I'm pleasantly surprised... It was most certainly worth the couple bucks and 10 mins of my time. CLICK HERE FOR THE HOGZAUST Link to comment Share on other sites More sharing options...
Max Capacity Posted July 31, 2009 Share Posted July 31, 2009 I worry about this guy with a torch...this is not going to turn out well. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rahulkatti Posted July 31, 2009 Author Share Posted July 31, 2009 well, my friend made a custom exhaust for his bmw some time ago and i have asked him to help and supervise me using the blowtorch. i have used a long wrench, but it seems the bolt head is starting to shred and hence i was thinking about cutting or heating it. I live in columbus, ohio Link to comment Share on other sites More sharing options...
Gire Posted July 31, 2009 Share Posted July 31, 2009 I worry about this guy with a torch...this is not going to turn out well. Like a guy wielding a chainsaw for the first time... Link to comment Share on other sites More sharing options...
Gire Posted July 31, 2009 Share Posted July 31, 2009 I for one am glad Hogmeat has recently re-surfaced. Howz the big truck running? Link to comment Share on other sites More sharing options...
hogmeat Posted August 1, 2009 Share Posted August 1, 2009 I've always been here, but just a little busy. work sucks, blah blah and the like. Truck is running good. Helped me get materials to use deadly power tools on! Ever seen a kid with no idea how to use a Skill Saw making his first ANGLED PLUNGE CUT while holding the guard out of the way and trying to trigger the safety latch and power switch all at the same time? heh heh. It, suprisingly (even to me!), ended well! I did keep most of my fingers, after all. I'm pleasantly surprised... It was most certainly worth the couple bucks and 10 mins of my time. CLICK HERE FOR THE HOGZAUST Link to comment Share on other sites More sharing options...
09SpecialEdition Posted August 1, 2009 Share Posted August 1, 2009 take your normal socket wrench or w/e you are using, and put an old pole or PVC pipe on the end, create leverage and BOOM free bolts Link to comment Share on other sites More sharing options...
lvethesnow Posted August 1, 2009 Share Posted August 1, 2009 had same problem. i torqued on bolt till it broke off then replaced bolt. History does not entrust the care of freedom to the weak or timid People sleep peacefully at night cause rough men stand ready to do violence on there behalf Link to comment Share on other sites More sharing options...
Platinum_Racing Posted August 1, 2009 Share Posted August 1, 2009 Ahh, the sound of an exhaust leak.... PB Blaster and an impact wrench. Best advice ever. I had to remove exhaust flange bolts on my 92 with 150K miles and PB + Impact Wrench did the trick. Spray it good with PB, let it sit (Overnight if possible), spray again in the morning, wait an hour or so and twist those suckers right off. If you break one it's no biggy, since a hammer will get it out no problem, and you can get that size bolt anywhere. If you want, you could try driving the car a bit before you take the bolts out to get them warmed up, but a torch would still be the best way to go if you're looking to get them hot. A small propane grill tank and a $10 torch kit from Wal-Mart/Home Depot will get 'er done..... take your normal socket wrench or w/e you are using, and put an old pole or PVC pipe on the end, create leverage and BOOM free bolts You could do that, but I'd suggest going with a 6 point socket in particular. A 12 point socket would be more likely to strip a bolt. If the bolt strips, cut it off. It's not like it's a grade 8 or even a grade 6 bolt (I don't think). An offset grinder, Dremel tool, or even a drill would work. Or just find someone with a bolt out and an impact wrench. If all else fails drive to my house and you'll be on your way in 5 minutes, Hawgzaust and everything... Link to comment Share on other sites More sharing options...
lilbrudder Posted August 1, 2009 Share Posted August 1, 2009 http://www.kanolabs.com/google/ this is all you need, trust me I live in Alaska, we more of 2 things than ANY other state......coast line and rust. Link to comment Share on other sites More sharing options...
lilbrudder Posted August 1, 2009 Share Posted August 1, 2009 ^that is a great deal, I literally just bought some. Link to comment Share on other sites More sharing options...
Platinum_Racing Posted August 1, 2009 Share Posted August 1, 2009 Well, if you guys say so... But if it doesn't work I'ma hit you both up for the $12.... :lol: Link to comment Share on other sites More sharing options...
Throttlejockey Posted August 1, 2009 Share Posted August 1, 2009 Kroil does work great too. I have some of that laying around I got from work years ago. Link to comment Share on other sites More sharing options...
zmarko Posted August 1, 2009 Share Posted August 1, 2009 I'd suggest picking up new nuts/bolts for it. If they're that rusted, you don't want to be re-using them (at least I wouldn't). Then I'd simply PB blast the hell out of them, and find a buddy with an impact wrench and get them off. Replace with the new nuts/bolts and you're good to go. Link to comment Share on other sites More sharing options...
