JonLGT Posted September 11, 2014 Share Posted September 11, 2014 Hey guys, it's been a while. On my 05 GT I have a invidia downpipe connected to a Greddy SP2 and one day started my car to find my exhaust sounded a whole lot louder than it did when I shut it off. I already knew I had some leaks in my cat back section due to old gaskets so I replaced them all expecting this to fix the issue. This made no difference at all. Now I have not removed the downpipe to check the gasket to the turbo but the leak sounds like it's coming from under the car. I recently inspected my piping for any holes or cracks bit it all looks good. I'm at a bit of a loss here. Anybody heard of this issue? The car runs exactly the same, holds boost properly and runs fine... just too loud. Oh and keep an eye on your shift linkage bushings. I had to replace mine at 96,000. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 11, 2014 Share Posted September 11, 2014 Get under the car when the engine running and see where the leak is. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AMileHighLGT Posted September 11, 2014 Share Posted September 11, 2014 have someone momentarily block the outlets and listen for the air leak. Link to comment Share on other sites More sharing options...
Rhitter Posted September 11, 2014 Share Posted September 11, 2014 I am not sure if this will work...but...if you have a camera that has a heat view mode could you point that at your exhaust to try and pinpoint the leaks? Obviously it would be better the colder it is outside. My OBXT build Link to comment Share on other sites More sharing options...
compsurge Posted September 12, 2014 Share Posted September 12, 2014 It could be the muffler disintegrating too. I've had that happen before. Link to comment Share on other sites More sharing options...
MrTris Posted September 12, 2014 Share Posted September 12, 2014 I am not sure if this will work...but...if you have a camera that has a heat view mode could you point that at your exhaust to try and pinpoint the leaks? Obviously it would be better the colder it is outside. Watch out -- James frickin' Bond over here! Link to comment Share on other sites More sharing options...
JonLGT Posted September 13, 2014 Author Share Posted September 13, 2014 Is it possible the timing belt has skipped a tooth? I'm going to replace it anyway but could this be the issue? There are no other strange noises coming from the engine. Link to comment Share on other sites More sharing options...
compsurge Posted September 13, 2014 Share Posted September 13, 2014 Highly unlikely the timing belt is the cause... Greddy isn't known for its quality. I'd look for holes in the pipes. Check near the hanger for a rusted through hole. Link to comment Share on other sites More sharing options...
