EvvLGTWagon Posted March 12, 2014 Share Posted March 12, 2014 I am looking to lower my 06 Legacy Wagon soon. I have decided on the H.Tech springs due to lowering distance. Though being that I have a wagon, it seems to be that I will have to use the "Saggy Butt" spacers to even out the front and rear. Question is which height should I use to even out my wagon? I figure it would be either the 1/4" or 3/8". I have tried to search for the differences but have yet to return may results. Thank you in advance Link to comment Share on other sites More sharing options...
boxkita Posted March 12, 2014 Share Posted March 12, 2014 confused why ppl don't buy front springs and rear springs, with rear springs being slightly taller so you can skip the spacers? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
EvvLGTWagon Posted March 13, 2014 Author Share Posted March 13, 2014 The only springs have found with those specs are the Swift springs. Any suggestions are welcome. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
discojon Posted March 13, 2014 Share Posted March 13, 2014 I have an almost brand new set of h techs, only on my wagon for about 500 miles. Had them on bilstein hds that exaggerated the sag. I think on stock struts I'd do 3/8 spacer. Pm me if you want a great deal on the springs. Sent from my SAMSUNG-SGH-I747 using Tapatalk Link to comment Share on other sites More sharing options...
bochinam Posted March 13, 2014 Share Posted March 13, 2014 1/4" at the most. Last time I put my wagon with H-Techs on the scales the car was already nose heavy. Raising up the rear a little might look "better" but it doesn't help the weight bias. I did try try 3/8" spacers since 5 people + a loaded up wagon rear = serious low rider. Without the load there is too much gap. If I were going to do it over again I'd go with the 1/4". Link to comment Share on other sites More sharing options...
