SlickSpur Posted September 12, 2012 Share Posted September 12, 2012 Its not just flashing on and off anymore, the display will actually totally go out. Today I was listening to my AUX output, and it shut it off and put on the radio, with no display showing up on the radio. Is my car Christine? Anyone have a fix for this? Thanks in advance Link to comment Share on other sites More sharing options...
.blackgt. Posted September 12, 2012 Share Posted September 12, 2012 You will be eaten alive by your car /thread Link to comment Share on other sites More sharing options...
SlickSpur Posted September 13, 2012 Author Share Posted September 13, 2012 You will be eaten alive by your car /thread Knew it! Link to comment Share on other sites More sharing options...
dr_sharp Posted September 13, 2012 Share Posted September 13, 2012 check battery and/or replace front faceplate of radio. lol Link to comment Share on other sites More sharing options...
bakabakablah Posted September 13, 2012 Share Posted September 13, 2012 check battery and/or replace front faceplate of radio. It's likely just a contact problem within the faceplate itself. You can either get a new replacement faceplate (expensive) or do a quick soldering fix (there should be a guide on here somewhere). Link to comment Share on other sites More sharing options...
Max Capacity Posted September 13, 2012 Share Posted September 13, 2012 Clean battery terminals, you may also want to think about replacing the battery with winter coming with the age of your car. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
SlickSpur Posted September 13, 2012 Author Share Posted September 13, 2012 Thanks for the tips guys! Link to comment Share on other sites More sharing options...
SlickSpur Posted September 13, 2012 Author Share Posted September 13, 2012 Looks like it may also be something with the board on the radio http://legacygt.com/forums/showthread.php/stereo-auto-climate-flashing-off-104569.html Link to comment Share on other sites More sharing options...
