joshuare Posted April 7, 2012 Share Posted April 7, 2012 Hi all - A friend of mine needs a new automatic transmission in his '98 Legacy Outback. I haven't done much work on this car (lots more experience with Toyotas and VWs), any one have any thoughts on this job? Any crazy tools or know-how one needs to accomplish it? Figure if I can save my friend a couple thousand in labor that would be nice. I switched out an AT in a '96 Honda Accord many years ago, it was a big job but I got it done. Any thoughts would be much appreciated. Link to comment Share on other sites More sharing options...
crash98 Posted April 7, 2012 Share Posted April 7, 2012 i cant say much for the autos but it was a pretty straight forward for the manuals. the drive shafts have pins in them that need to be driven out a punch does the trick but they do make a special punch for them. Link to comment Share on other sites More sharing options...
joshuare Posted April 8, 2012 Author Share Posted April 8, 2012 Thanks for the advice... any suggestions on where to buy a good used AT? Also, the special punch you spoke of? Link to comment Share on other sites More sharing options...
travisbiechy Posted April 8, 2012 Share Posted April 8, 2012 i also have more experiance with manual transmissions, but i know when i did my clutch i didnt take the drive shaft pins out. its been a while but i believe i dropped the drive shaft hanger. and that gave me enough slack to pull the whole shaft out of the trans. i couldnt get the pins out. the only downfall is some of the gear oil will drain. also i had to pretty much beat mine off with a hammer and a block of wood. also you may have to take out the top motor mount to let the motor rock back so you can get to all of the bolts. but like i said its been a while since i did one. Link to comment Share on other sites More sharing options...
monkeyposeur Posted April 8, 2012 Share Posted April 8, 2012 Use a 3/16" punch pin with no taper. Like this: [ame=http://www.amazon.com/SK-Hand-Tool-6156-Punch/dp/B000RN4PEC]Amazon.com: SK Hand Tool (SK 6156) 3/16" Roll Pin Punch: Home Improvement[/ame] About $6. Link to comment Share on other sites More sharing options...
johnegg Posted April 10, 2012 Share Posted April 10, 2012 used trans www.car-part.com put in your zip, shipping will add about $150. you can uase an auto trans from ANY 2.5L car, from 96 - 98. you will have to search each year separately. that means Outbacks, GTs or LSi. the speedo may be off if you use the LSi trans.. Link to comment Share on other sites More sharing options...
