CHUCKmfnNORRIS Posted October 7, 2012 Share Posted October 7, 2012 i have a '11 2.5i with a 6 speed trans, i need to find a way to get a 1/0 gauge wire through the firewall. if it was an automatic trans it would be easy, but the manual clutch reservoir uses a 1 1/4" hole in the firewall that the auto trans doesn't. has anyone found a good area to drill a hole or a way to use an existing hole? Link to comment Share on other sites More sharing options...
CHUCKmfnNORRIS Posted October 9, 2012 Author Share Posted October 9, 2012 bueller..... Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted October 9, 2012 Mega Users Share Posted October 9, 2012 haha. what in gods name are you putting in your car that requires a 1 gauge wire. "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
CHUCKmfnNORRIS Posted October 9, 2012 Author Share Posted October 9, 2012 a 2500watt rms amp Link to comment Share on other sites More sharing options...
SUPERBU Posted October 11, 2012 Share Posted October 11, 2012 haha. what in gods name are you putting in your car that requires a 1 gauge wire I was wondering the same thing. Are you talking about an old school amp that actually draws a lot of current or a new amp that has 2500 "digital" watts. Take a look at the fuses on the amp. It probably has a pair of green 30 amp fuses. Not picking on you. It's just that 1/0 gauge is more for SPL vehicles with multiple amps and additional batteries. My last car had (2) 4/0 guage runs for 3 amps and that was probably overkill. Getting back to your original question...... I wonder if the newer Legacy's still have a gromit in the wheel well. You just pull down the drivers side plastic fender skirt and it's right there. Nice and easy. Link to comment Share on other sites More sharing options...
mark5032 Posted October 11, 2012 Share Posted October 11, 2012 I swear I saw a thread somewhere here or on the Outback forum about running an amp power wire through the firewall of a car with a manual transmission. I don't think they were running a wire quite that large though Link to comment Share on other sites More sharing options...
Rusty9 Posted October 12, 2012 Share Posted October 12, 2012 there should be a hole with a grommet behind the felt under and to the right of the pitch stop mount. if you push the cable down from there it exits near the gas pedal. Link to comment Share on other sites More sharing options...
FJuan Posted October 12, 2012 Share Posted October 12, 2012 I found it easier to run it through the driver side wheel well to the kick panel next to the dead pedal. This way you have a straight shot to the trunk. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
CHUCKmfnNORRIS Posted October 13, 2012 Author Share Posted October 13, 2012 I was wondering the same thing. Are you talking about an old school amp that actually draws a lot of current or a new amp that has 2500 "digital" watts. Take a look at the fuses on the amp. It probably has a pair of green 30 amp fuses. Not picking on you. It's just that 1/0 gauge is more for SPL vehicles with multiple amps and additional batteries. My last car had (2) 4/0 guage runs for 3 amps and that was probably overkill. Getting back to your original question...... I wonder if the newer Legacy's still have a gromit in the wheel well. You just pull down the drivers side plastic fender skirt and it's right there. Nice and easy. this is the amp im going to be running. i plan on using xspower batteries, Knu Konceptz wires, mechman high output alt. and im putting 2 of these in my trunk Link to comment Share on other sites More sharing options...
CHUCKmfnNORRIS Posted October 13, 2012 Author Share Posted October 13, 2012 i think my best bet is to find a safe place to drill a large enough hole to fit my grommet. but that needs a 1 and a 1/8 inch hole. Link to comment Share on other sites More sharing options...
SUPERBU Posted December 28, 2012 Share Posted December 28, 2012 Jeezus that amp has a set of balls attached to it. That looks like it will definitly pull some current from your alternator. I think you should go with 4 of these: http://store.soundsolutionsaudio.com/products/sundown-audio-sa-8v-2-600w-sa-series.html Link to comment Share on other sites More sharing options...
