Need a new transmission now, possible to switch from 5EAT to 5/6MT?
The transmission on my 05LGT was destroyed because of lack of fluid
Since it already costs a lot money to get a new transmission, I'm thinking is it possible to switch from 5EAT to 5/6MT? And how much will it cost if possible? Can transmission shop do this? Transmission work is definitely beyond my ability...
  • Moderators
7 grand.
that's hear say from other threads in the past. if you do NONE of the work, expect to pay at least that much. If you're totally clueless (i don't mean this as an attack/insult) you should probably just replace the AT and call it a day. if you are going to keep the car put in a hexmods f1 valve body and make sure your fluid level is up (it should not have gone down unless you have a leak of some sort, FYI).
Not currently in stock :(
