yogis wagon Posted January 12, 2011 Share Posted January 12, 2011 I'm looking to put Brembo's on my 08 SpecB, but I still want to keep my OEM rims for my winter tires. What size of spacer will I need to be able to that. The only answers I can find are not 100% certified. I've seen around 10mm, but nothing confirmed. And don't worry about stud lenght, I'm gonna use longer ones !! Link to comment Share on other sites More sharing options...
Drift Motion Posted January 12, 2011 Share Posted January 12, 2011 You should just get still wheels or other wheels that clears the caliper Spacers kills bearings Link to comment Share on other sites More sharing options...
Pricci09 Posted January 12, 2011 Share Posted January 12, 2011 Spacers are not necessarily any worse for your wheel bearings then running a low offset wheel I believe that stock 05 LGT wheels require a 15mm spacer to clear brembos, if that helps at all Link to comment Share on other sites More sharing options...
