shtbxr22 Posted September 8, 2012 Share Posted September 8, 2012 So, it happened. http://i104.photobucket.com/albums/m194/star91281/2012-09-01_17-12-49_461-1.jpg Link to comment Share on other sites More sharing options...
Leviman Posted September 8, 2012 Share Posted September 8, 2012 Is that truly a crack? Looks like it's right at BDC, why would it crack there? Link to comment Share on other sites More sharing options...
Max Capacity Posted September 8, 2012 Share Posted September 8, 2012 By chance is that #2 cylinder ? That'll buff right out....LOL What's your plan ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
shtbxr22 Posted September 8, 2012 Author Share Posted September 8, 2012 Faulty boring procedure by the machinist. Link to comment Share on other sites More sharing options...
shtbxr22 Posted September 8, 2012 Author Share Posted September 8, 2012 By chance is that #2 cylinder ? That'll buff right out....LOL What's your plan ? #3 cylinder. I thought about jb weld, but I got a new set of block halves instead. Link to comment Share on other sites More sharing options...
-Samurai- Posted September 8, 2012 Share Posted September 8, 2012 Doesnt even look like a crack. Merely a mark lol. Link to comment Share on other sites More sharing options...
shtbxr22 Posted September 8, 2012 Author Share Posted September 8, 2012 You can catch your finger nail on it. its cracked for sho! Link to comment Share on other sites More sharing options...
ehsnils Posted September 8, 2012 Share Posted September 8, 2012 Failure in the casting process. Depending on how deep it is and location it can range from harmless to a coolant leak. Link to comment Share on other sites More sharing options...
fahr_side Posted September 8, 2012 Share Posted September 8, 2012 Oops. Given the location I'd say it's a manufacturing defect and no fault of yours. Of course most major blow-ups start with or at a tiny flaw, so good call on scrapping the block. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
shtbxr22 Posted September 8, 2012 Author Share Posted September 8, 2012 11k mile 2011 sti block stock bore size should do well. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted September 8, 2012 I Donated Share Posted September 8, 2012 Didn't a bunch of people say this was going to happen? Link to comment Share on other sites More sharing options...
CapnJack Posted September 8, 2012 Share Posted September 8, 2012 Says it works to fix automobiles too! Link to comment Share on other sites More sharing options...
dr_sharp Posted September 10, 2012 Share Posted September 10, 2012 Says it works to fix automobiles too! Thanks x 1000. lol Link to comment Share on other sites More sharing options...
shtbxr22 Posted September 10, 2012 Author Share Posted September 10, 2012 Didn't a bunch of people say this was going to happen? Yep Link to comment Share on other sites More sharing options...
jaxx4k Posted September 11, 2012 Share Posted September 11, 2012 By chance is that #2 cylinder ? That'll buff right out....LOL What's your plan ? I think I have cyclinder2 problem... keep throwing miss fire code... do tell me more bout your #2?? Link to comment Share on other sites More sharing options...
shtbxr22 Posted September 11, 2012 Author Share Posted September 11, 2012 Yours is probably a ringland, or valve adjustment issue. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 11, 2012 Share Posted September 11, 2012 I think I have cyclinder2 problem... keep throwing miss fire code... do tell me more bout your #2?? There is a timing flaw in the OEM engine map. The issue results in burnt valves. For some reason #2 seems to be the first one to go bad enough to start the CEL. Tuners have found the flaw in the map. When I mentioed that to my Machine shop buddy, he said, "that may explain why we see so many heads from the Dealerships with burnt valves". When they rebuilt my heads, they could see a difference from what they are used to seeing with these heads. I have been in Cobb AP or a custom tune since 8000 miles on the car. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
