davester_exallroad Posted May 7, 2012 Share Posted May 7, 2012 2005 Legacy GT AT <80k miles. Stock I got a ECL and blinking cruise and sport lights. They all turned off for 5 miles and then back on. I pulled the codes and got: P0763 Shift Solenoid C Electrical P0700 Transmission Control Module (TCM) monitors the malfunction of sensors and actuators relating to transmission control Has anyone had these codes? What do these codes mean in "human" speak? How much do you think this will cost? Possible causes of OBD code P0763 - Faulty shift solenoid C valve - Shift solenoid C valve harness or connectors - Shift solenoid C valve circuit is open or shorted - Low transmission fluid level - Dirty transmission fluid The Error code is generally activated on detection of the following conditions: The P0763 code is detected when the gear required by the ECM does not match the actual gear when vehicle is driven. Possible causes of OBD code P0700 - Shorted or open circuit within transmission control module (TCM) - Failure of transmission control module Link to comment Share on other sites More sharing options...
davester_exallroad Posted May 8, 2012 Author Share Posted May 8, 2012 For the record. The Technical Service Rep gave me a call. Those codes mean I need to replace the entire valve body. 3 days wait for the part and $1400.86. Good thing I have the 10% off coupon. Link to comment Share on other sites More sharing options...
OGHK87Jay Posted May 9, 2012 Share Posted May 9, 2012 I had the P0700 and some other code. Result for me was tranmission and tc was toast and had both replaced under warranty http://legacygt.com/forums/showthread.php/5eat-transmission-keeps-stalling-shifting-into-r-and-d-160271p2.html?highlight=transmission Link to comment Share on other sites More sharing options...
davester_exallroad Posted May 15, 2012 Author Share Posted May 15, 2012 Car has been in the shop for 8 days. They replaced the entire valve body and found out that the sensor was not ground properly so they removed and re-installed the valve body. Everything came out ok with the valve body but found out that I need a new TCM (please add $585, labor is free). The service advisor is telling me that the faulty TCM is what caused the valve body to short out and usually shorts out more than one solinoid. So subaru has me spending $2000 on a car that is only worth $10-12K. I was under the impression that Japanese cars had more reliable electronics than other makes. Anyone know where I could send a letter to Subaru corporate to tell them how annoyed I am. Link to comment Share on other sites More sharing options...
bmx045 Posted May 16, 2012 Share Posted May 16, 2012 Car has been in the shop for 8 days. They replaced the entire valve body and found out that the sensor was not ground properly so they removed and re-installed the valve body. Everything came out ok with the valve body but found out that I need a new TCM (please add $585, labor is free). The service advisor is telling me that the faulty TCM is what caused the valve body to short out and usually shorts out more than one solinoid. So subaru has me spending $2000 on a car that is only worth $10-12K. I was under the impression that Japanese cars had more reliable electronics than other makes. Anyone know where I could send a letter to Subaru corporate to tell them how annoyed I am. I see you're new at this. Link to comment Share on other sites More sharing options...
davester_exallroad Posted May 16, 2012 Author Share Posted May 16, 2012 bmx045, I bought the car new and thought it would be as reliable as my 1988 toyota pickup. I am more an end user rather than a power user. Are you saying that Subarus are unreliable and the Subaru corporate is unresponsive to letters and complaints? Please elaborate. Link to comment Share on other sites More sharing options...
bmx045 Posted May 16, 2012 Share Posted May 16, 2012 You have a turbo subaru, reliability is nothing like the N/A versions. Your failure is an isolated event compared to the transmission issues brought up on this forum, writing a letter to a company doesn't get you very far, usually. You also generalized that since its a japanese car that it's automatically reliable, you bought the car thinking this Even the most reliable of cars have failures once in a while, reality check. A turbo subaru isn't the first vehicle i would choose for reliability if i was limited to japanese, I'd probably choose a toyota corolla. You were unfortunately duped by marketing of subaru and their reliability(which is primarily true for n/a subarus and also the 2.2L platform). There are the unicorn turbo subarus that run 200k miles without any major failures but that is VERY far and few between. The longer you look through this forum the more you'll realize these cars and platform need special attention or else you can quickly find yourself in a huge credit card minimum monthly payment. Link to comment Share on other sites More sharing options...
davester_exallroad Posted May 17, 2012 Author Share Posted May 17, 2012 I guess it's time to trade her in sooner than later. Thanks for the heads up. Link to comment Share on other sites More sharing options...
fishbone Posted May 23, 2012 Share Posted May 23, 2012 I think you are overreacting. Unfortunately sensors do go bad all the time as well as electrical connectors. Personally I may inquire into the reason of the TCM failure because a fried sensor shouldn't take it out. And you are right, Japanese cars supposedly tend to be more reliable but what you need to understand is NONE are perfect. I can counter your anecdotal evidence with my own. I am at 94K, I have not been stock since 40K-some miles and I have had zero issues. I understand your frustration but unfortunately these things do happen. Reliability is disputed around here and in my opinion the issues are overblown. Link to comment Share on other sites More sharing options...
Lardo420 Posted May 23, 2012 Share Posted May 23, 2012 i wrote a letter to subaru and complained once. they came to my house took a dump in a paper bag rang the doorbell and ran away Link to comment Share on other sites More sharing options...
bmx045 Posted May 23, 2012 Share Posted May 23, 2012 subaru tossed a dead one of these through my window once: http://profile.ak.fbcdn.net/hprofile-ak-snc4/41569_379589385314_1336_n.jpg Link to comment Share on other sites More sharing options...
fishbone Posted May 23, 2012 Share Posted May 23, 2012 Well apparently SOA sold me a magical unicorn. Link to comment Share on other sites More sharing options...
