Rocker Switch Question
I am going to do the Power Mode mod to my '93 SS w/4EAT. This involves grounding pin 4 of the TCU. I want to install a switch so I can turn power mode on an off.
A simple toggle (two prongs) switch on the ground wire would work, but it would be cool to have one with an led. I bought a three pin rocker switch with a red LED. It has three prongs, (power, accessory, and ground). However, I am not sure if it would work since it is normally used to power an accessory.
Can I use this rocker switch as a simple ground switch or will it send a current to the TCU? I don't want to do that.
TIA
Right, that's how my rear defroster switch is for example. But in this case I am not wanting to power something, just switching/connecting a ground. I found this image of an led rocker switch. In the diagram the acc wire is powering an led light source. I don't want to get a voltage through the acc wire in my case. I am thinking this setup won't work for what I want and I might just have to use a two prong toggle switch instead.
I guess I better get out the multimeter and play around with the switch.
I really want this light to go on when I engage the switch, lol. Now I am thinking that I can wire the switch to a relay that will connect the ground from the TCU pin to the chassis when I hit the switch. I've never messed around with this kind of stuff so if anyone has any ideas let me know. Would a 4-pin relay work for this application?
Maybe this will work. Just connect the ground line coming out of the tcu pin to the power source of the switch, connecting the chassis ground to the ground pin, and not even messing with the accessory pin.
I hooked the switch up to a 9 volt battery and the light comes on in this setup. I'll test it out tomorrow and let you know if it works. But I am thinking that there is current coming out of the grounded pin wire flowing to the chassis, so putting the LED switch should still allow it to power up.
edit: The reason I want to use this rocker switch is that it looks nice and has a light. All the two pin toggle switches at the auto parts stores didn't have lights and stick out.
  • I Donated
What's the "Power Mode" mod? Sounds cool haha
Its where you put a bunch of rice in your gas tank.
....it locks the transmission in a 50/50 torque split
-broknindarkagain
My Current Project - Click Here
COME AND TAKE IT
"The only thing necessary for the triumph of evil is for good men to do nothing."
If anyone figures out how to get this to work, I would literally pay them $15 if they know how, because I've got two lighted toggles for both the FWD and Power Modes on my car, and I can't figure out how to get them working. I can get either the light and no activation of the function, or the function, but no activation of the light, but not both.
  • I Donated
It can't be done with the switch alone...
The only option you have is to add a relay into the circuit. I'll work on a diagram for you.
-broknindarkagain
COME AND TAKE IT
Power Mode changes the shift logic (mapping) of the TCU. It's "Sport Mode" with a more aggressive name, lol.
EDIT: Brok, I have tried every combination of those three and I have yet to get both the light and whatever feature I am trying to enable to work at the same time. It sucks.
Power mode was offered in the JDM SVXs w/4EAT at the push of a button. The USDM 4EATs have the same programming and maps in their TCUs but we didn't get a button. In our TCU harnesses we have an empty pin. All we need to do is ground that pin.
SVX guys figured it our first: http://www.rs25.com/forums/f8/99075-4eat-diff-lock-switch-handbrake-mod-torquemada-lite-2.html
BBS was next to figure out how to access it in first gens: http://www.rs25.com/forums/f8/99075-4eat-diff-lock-switch-handbrake-mod-torquemada-lite-2.html
It is just like stang70 said. It delays the shifting maps which allows you to get to higher rpms before shifting. It also 'listens' to how much you are depressing the throttle. If you are pressing the pedal a lot you can delay the shift to a lower gear and get a sportier experience, lol.
The 50/50 split that brok referred to can be wired to a separate switch thusly (you will need to wire in some resistors to make it work): http://www.rs25.com/forums/f8/99075-4eat-diff-lock-switch-handbrake-mod-torquemada-lite-2.html This is not the same mod as the power mode mod.
Second gens w/4EAT can also do the power mod. It is a different pin though. Pin #4 in first gens.
Wire the switch to simple relay like an ignition relay. Instead of the relay closing the switch and applying power to an accessory, have the relay close the switch to ground.
I am pretty sure this will work to illuminate your switch and to ground out your pin...
Read this for awhile don't see why it won't work.
http://www.autoshop101.com/forms/hweb2.pdf
  • I Donated
If you get a standard 5 prong relay you should see a diagram on it printed somewhere. Match the diagram to what I have in the image. Depending on teh relay, the numbers on it may change.
This is the only way you will be able to do it.
Click on the image for a bigger size. Excuse my microsoft paint artwork.
basically the way it works is the ground wire coming off the ECU will go through the relay. That side of the relay is like a light switch in the off position. When you send 12v through the other side of the relay, it creates an electromagnet that basically turns the light switch on the other side on (it physically pulls the connection together on the other side).
Kind of hard to explain, but it will work.
-broknindarkagain
COME AND TAKE IT
  • I Donated
I had already said that......lol
This is the type of relay I used for my off road lights. It was pretty straight forward.
In your case, your pinout would be :
85 - switch
86 - chassis ground
30 - ecu
87 - chassis ground
87a would not be used
Just make sure you use low power relays.
-broknindarkagain
COME AND TAKE IT
Brok beat me to the relay idea, I just type real slow. (and he called me out on it and I'm slow once again)
Why would you need a 5 pin relay to make it work? Does the pin normally get power, then you ground it out instead to get power mode?
If it doesn't get power and its just a blank pin, I'd think you could use a 4 pin relay.
Or are 5 pin relays more common/easier to get at the parts store?
  • I Donated
You can use a 4 pin relay....5 pin relays are more common though in automotive.
And I answered your question already, you were just slow to type lol
the coil side of the relay is the +12v side. When it is energized (via the switch), it will pull the other side closed (ecu ground side) to complete the ground circuit.
This keeps the switch on a positive circuit (like what is needed to turn its light on) and still allows that switch to control the ECUs ground.
Take a look at the relay picture I posted. When you send live power through 85/86, it literally pulls the diagnal line over (the one between 30/87) to complete that circuit. There is no physical connection between the two sides of the relay. It works via magnet.
-broknindarkagain
COME AND TAKE IT
  • I Donated
Brok, what's a low power relay? Thanks BTW.
Not a problem.
Relays are capable of holding x amps of load. For example, I have a 30 amp relay for my off road lights. For what you're doing, you only need a 5 amp relay. You're not going to hurt anything by using a relay rated for more power, so your options are pretty open. I don't know if a 5 amp relay will be cheaper then the higher amp ones.
-broknindarkagain
COME AND TAKE IT
