sutter2k Posted May 27, 2006 Share Posted May 27, 2006 I currently have clunking in the front(didn't do the back yet). I am curious how does one you tighten the top nut down? The strut assembly spins while trying to tighten it. In addition, it doesn't use an allen wrench like the stock shocks. Is there a special tool for these? Thanks Matt Link to comment Share on other sites More sharing options...
Ridgeracer Posted May 28, 2006 Share Posted May 28, 2006 If it doesn't have a chamfered edge to grab then use an impact gun on the low setting. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
SWortham Posted May 28, 2006 Share Posted May 28, 2006 ^ Agreed. I had to do the same thing with my KW's. Link to comment Share on other sites More sharing options...
sutter2k Posted May 28, 2006 Author Share Posted May 28, 2006 Really?? Impact wrench will turn nut without turning rod? Impact impact wrench is quite powerful. I'll turn running on a lower psi. Link to comment Share on other sites More sharing options...
SWortham Posted May 28, 2006 Share Posted May 28, 2006 Yeah, it will. I mean, the rod will spin a little but the nut will spin more. In fact once it's tightened down a little with the impact wrench, the rod won't spin anymore and then you can take a torque wrench to it to torque it properly. Link to comment Share on other sites More sharing options...
Hops Posted June 17, 2007 Share Posted June 17, 2007 I just installed my fronts... Had to use the impact wrench on the top nut as well. Tried using the torque wrench afterwards but it still spun. I was afraid to tighten it too hard as the instructions say not to use one as it will void the warranty, so I tightened it just enough for the small top piece of the rod to come up past the rubber surround of the nut. What does everybody else's look like and how far did you tighten yours? Buy my cars! Link to comment Share on other sites More sharing options...
Hops Posted June 17, 2007 Share Posted June 17, 2007 Please help! Buy my cars! Link to comment Share on other sites More sharing options...
Boostjunkie Posted June 17, 2007 Share Posted June 17, 2007 Just use the impact gun and don't worry about it. It won't hurt them. The rod will spin, but the nut will tighten down. Stop when you get the characteristic change in sound from the impact gun of a fastener being tight. You really can't overtorque it because the rod will spin. Link to comment Share on other sites More sharing options...
Hops Posted June 18, 2007 Share Posted June 18, 2007 Just use the impact gun and don't worry about it. It won't hurt them. The rod will spin, but the nut will tighten down. Stop when you get the characteristic change in sound from the impact gun of a fastener being tight. You really can't overtorque it because the rod will spin. Awesome. So there really is no way to check torque? About how far should the piston come up past the nut? On the front it comes up about 5 mm. I did the same on the back then it was bouncing around. I'll be tightening them up tomorrow when I get back to my shop. I just want to make sure I do the right thing cause these babies are a pain and also expensive! Buy my cars! Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted June 18, 2007 Share Posted June 18, 2007 uhh.....strap wrench people? keeps the shaft from spinning, and you won't snap the top nut. - Andrew Link to comment Share on other sites More sharing options...
Hops Posted June 19, 2007 Share Posted June 19, 2007 uhh.....strap wrench people? keeps the shaft from spinning, and you won't snap the top nut. - Andrew Where do you get one? I already have them set and they are doing killer now. I just used the impact wrench til it was tight and now it's good! Buy my cars! Link to comment Share on other sites More sharing options...
Boostjunkie Posted June 20, 2007 Share Posted June 20, 2007 You're fine. Leave them alone. The strap wrench is a great idea for guys who don't have good air tools, but since you do, there is no reason not to take advantage of them. Carefully used, tightening the top nut with an air impact gun won't cause any harm and is a ton faster and easier. Link to comment Share on other sites More sharing options...
