jeepr Posted April 12, 2011 Share Posted April 12, 2011 Okay, since just about everyone focused on the hvac part of my previous post, I'll try this again. If I pull my 08 Leggy out of the garage where it is cool, and drive outside where it's easily 20 degrees warmer, it takes my outside display on the dash probably 20-30 minutes before it comes up to near the right temperature. The dealer said "yeah, they are slow"... but 20-30 minutes!!?? How long does yours take to respond to temperature changes? Link to comment Share on other sites More sharing options...
HCF Posted April 12, 2011 Share Posted April 12, 2011 20-30 seems a tad long.. but id say easily 10 mins here. It seems to remember the temperature of my garage, and the tick the degrees as needed one by one. Happy just to have it really, It is nice to keep an eye on the lower/mid 30s to see when ice is possible. Link to comment Share on other sites More sharing options...
Madjik_Man Posted April 13, 2011 Share Posted April 13, 2011 10 minutes tops for me. I sometimes see it blink once. I think that's when the sensor is taking the first reading. Link to comment Share on other sites More sharing options...
lee07 Posted April 13, 2011 Share Posted April 13, 2011 2 or 3 minutes tops. Usually changes right away but I'll say 2 - 3 minutes top. Link to comment Share on other sites More sharing options...
biketowork Posted April 13, 2011 Share Posted April 13, 2011 Mine is the same as lee07, about 2 minutes tops. Usually 30 seconds out of the garage there will be a new reading. Link to comment Share on other sites More sharing options...
milesej05 Posted April 13, 2011 Share Posted April 13, 2011 ^^^ Same as the previous two posts. Link to comment Share on other sites More sharing options...
jeepr Posted April 13, 2011 Author Share Posted April 13, 2011 Thanks guys, I'll get back to the dealer and won't take "it's fine" for an answer then. Link to comment Share on other sites More sharing options...
Scooby Fan Posted April 13, 2011 Share Posted April 13, 2011 I had mine stay on the same number for days last winter.....the temperature was obviously changing daily but the "Outside temp" display never moved. I took it to the dealer to have it checked and they told me that the display is actually distance related and so it will not change with a series of very short drives.....I took it for a drive on the freeway (About 15 Km) and sure enough it started working normally right away......seems a little bogus but there is no doubt that mine changes very readily on long hauls but sometimes stay on the same number for a long time if I don't drive too far...... My local golf course is 2.5 Km from my house and it NEVER changes on that trip. For what it's worth the dealer tech says it takes about 5-8 Km to trigger the change. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 13, 2011 Share Posted April 13, 2011 OP you have a SpecB so it must be correct. I don't have a garage but do live in a area that is normally 6-7F cooler then when I get to the top of the hill about a mile away. Both cars will change temps with in a 1/4 mile. I see this everyday on my drive to work and even coming home in the afternoon. As I coast down the hill I can watch the temp drop. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Adoniram Posted April 14, 2011 Share Posted April 14, 2011 FWIW: Garage this am was 63. Within 1 minute, it read 54. Within 5 minutes, it read the correct temp of 48. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted April 14, 2011 Share Posted April 14, 2011 My outside temp and the real outside temp vaguely resemble each other at any time. Link to comment Share on other sites More sharing options...
Val Demar Posted April 14, 2011 Share Posted April 14, 2011 Had similar issues on my 05 LGT, bought a replacement ambient temperature sensor for like $6, took 3 minutes to swap - problem gone. Link to comment Share on other sites More sharing options...
soloz2 Posted April 14, 2011 Share Posted April 14, 2011 Mine doesn't seem to be accurate... It takes at least 15 min or so before it'll give a semi-accurate reading and I can't trust it till I get to work which is a 22.5mile drive. Current: 16 Crosstrek Premium w/ Eyesight & 05 Outback XT 5MT Past Subies: 14 FXT Premium, 14 WRX hatch, 06 Legacy 2.5i SE 5MT, 98 Outback wagon Link to comment Share on other sites More sharing options...
Max Capacity Posted April 14, 2011 Share Posted April 14, 2011 Started the car in the driveway, read 44F, rolled down the 125ft drive to the street, picked up the paper from the paper tube, put the car in gear, drove past the third house, now it reads 43F. Got to the top of the hill 1 mile to the west of the house, now it reads 47F. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jeepr Posted May 24, 2011 Author Share Posted May 24, 2011 As a follow-up.....Finally got it to the dealer today, I stood my ground that it was not "normal" (thanks to the feedback from everyone here) so they took a look at it and then said they did eventually witness the sensor sticking, so they replaced it. Thanks everyone. Link to comment Share on other sites More sharing options...
milesej05 Posted May 24, 2011 Share Posted May 24, 2011 Good to hear, and I believe thats what the rest of the LGT.com community is here for! Link to comment Share on other sites More sharing options...
britnick Posted May 26, 2011 Share Posted May 26, 2011 My 05 exterior temp is consistently high in readings. Sounds like I may need to replace the sensor. Does anyone have part# and or instructions for that? From a previous post this sounds easy and low cost. A search of the forums wasn't much help though in exactly how that is done. All help appreciated. Link to comment Share on other sites More sharing options...
