Moore built forester XTi - 5 speed + twin-scroll = 622WHP
Event: dyno pull
Ambient Temp: 48 degrees fahrenheit
Elevation: 620 feet above sea level
Weather: wet
Tires: Crusade HP (yes, I said CRUSADE - I never heard of them either) on Forgestar F14's
Car: 2005 Subaru Forester XTi
Tuner: Mike @ Innovative Tuning
Dyno Info: Mustang AWD dyno
Transmission: 5 speed Subaru gearset with Moore Performance BlastPlates
Gear: 3rd
Peak HP at RPM: 622@7600
Peak Torque at RPM: 465@6500
Baseline hp/tq for a stock on same dyno: 08 STi = 240 hp
Target Boost: 33 psi
Target AFR: varies with boost
Fuel: pump E85
Engine/Power Modifications:
- Moore Performance World "street" twin-scroll header and Adaptor (stock-style JDM up-pipe to T4 rotated flange)
- Borg Warner non EFR s300 twin-scroll turbo - 66mm. 82 lb/min compressor flow.
- Twin Tial 38mm wastegates and 50mm BOV
- Moore Performance full 4" v-banded downpipe
- Moore Performance 3.5" downpipe-back exhaust
- Moore Performance air-to-water oversized heat exchanger and 4 gallon ice reservoir
- Moore Performance 2.5L non-sleeved shortblock - Manley rods and pistons, ACL bearings. 7.8:1 compression.
- Moore Performance engine BlastPlates - block reinforcement/windage system
- Killler B Motorsports reinforced oil pan pick-up
- Perrin EBCS in dual port configuration
- Moore Performance 25B heads - full CNC port, +1mm in/out valves, Moore-spec regrind.
- Moore Performance sheet metal intake manifold with built in dual air-to-water intercoolers featuring Bell cores. Stock STi throttle body phased 90 degrees.
- Grimmspeed 3mm phenolic spacers
- Moore Performance Scavenger series catch can/evacuation system
- Moore Performance -6 an parallel fuel rail kit with Fuel Injector Clinic 2100cc injectors, Aeromotive A1000 regulator
- Moore Performance in-tank dual pump setup featuring Jay Racing Pro Series 342 pumps.
- Green Filter USA 4" I.D. by 12" long conical filter.
- Cobb Accessport v.2 in full speed density mode. Calibrated by Mike @ Innovative.
Driveline Modifications:
- Moore Performance transmission featuring 2002 Subaru WRX transmission case, Subaru 5 speed gearset, carrier for STi plug-in axles and metal speedo gear.
- Moore Performance BlastPlates - transmission strengthening system.
- Moore Performance Dragon's Blood transmission fluid.
- Carbonetic triple carbon clutch and clutch-pack r180 rear differential.
Other Modifications:
- Moore Performance MooreCool Race Coolant in both the radiator and the air-to-water system.
The Fozzy XTi has long been a testbed for all sorts of Moore-branded parts; we never know how certain combos are going to turn out until they go from paper to the dyno...but it's fun finding out!
The goal this round was a mix of both low-end response and top-end power...all while funneling it through a Subaru 5 speed trans and a non-sleeved block. We're very happy with the results of the BlastPlates for the transmission that we've been offering for awhile now, not to mention the prototype of our new girdle/windage brace! We're also closer to a
production-style intake manifold with this round of testing. Furthermore, we have some new tweaks to try out for our twin-scroll specific camshaft and CNC porting programs.
All-in-all this is a solid-performing setup that, with a few modifications, has the potential for faster spool...even through there's still headroom in both compressor and turbine flow; I guess we'll see what happens next round. But until then, a big thanks to Mike @ Innovative Tuning for the stellar calibrations, Mike Vindler for his CAD/Forester-specific prowess and Jason Economu at Carbotron for the late night whiteboard sessions.
Awesome build. Great shop. Great owner. Great experiences there every time I've needed something subie related.
Congrats on a beast of a Foz.
"Striving to better, oft we mar what's well." - Bill Shakespeare - car modder
  • 1 month later...
  • 8 months later...
How is the trans holding up with those blast plates?
Sorry for the old thread revival
trans held up great, bad news is we have short attention spans...
[ame=http://www.youtube.com/watch?v=qnzezqXbaxg]2005 Moore Performance Forester XT Loud Exhaust - YouTube[/ame]
best car to be watching with the blast plates is this one:
2009 WRX 751awhp/ 638 lbs tq STOCK TRANSMISSION!
  • 2 weeks later...
