ericem Posted January 27, 2012 Share Posted January 27, 2012 Anyone experience this ? I am thinking it is normal, but also thinking it should be perfect. Lets say i start the car cold the rpm's are up at 2k than as the engine warms up slowly get the 1000-1100 but can flucuate up and down 100 rpm's. I recently got a infamous tune which made it a bit better. I probably have a slight vacuum leak. I have gotten out and sprayed water all over the manifold and doesn't change, can't really soak my inlet, but I am thinking my inlet is most likely damaged from the dealership removing it to replace OCV's. I also get missing whenever it's below freezing or close too it. Has new plugs also! Link to comment Share on other sites More sharing options...
Drift Motion Posted January 27, 2012 Share Posted January 27, 2012 Maybe the ECU is "re-learning" the car? when you disconnect the battery for a while, and during the first few cycle of start up, the RPM will drop pretty low at idle. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 27, 2012 Share Posted January 27, 2012 Have you cleaned the MAF and IAT lately ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mwiener2 Posted January 27, 2012 Share Posted January 27, 2012 did the new spark plugs have a -11 at the end? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
ericem Posted January 28, 2012 Author Share Posted January 28, 2012 no they were the .44 gap but regapped to .32 Link to comment Share on other sites More sharing options...
joop1987 Posted January 28, 2012 Share Posted January 28, 2012 Maybe it's the gaskets between the manifold and tumbler guides. Link to comment Share on other sites More sharing options...
ericem Posted January 30, 2012 Author Share Posted January 30, 2012 ya thinking that too ^^ but seems like this started after doing the spark plugs. Checked the passenger side plugs found one slightly loose I should have lubed the threads and the outside of the socket so it doesn't bind up while tightening it up. Going to check the driver side tomorrow what a pain in the ass stupid compressor pipping. Link to comment Share on other sites More sharing options...
MasAyinde Posted January 30, 2012 Share Posted January 30, 2012 Correct me if I'm wrong, but wouldn't a vacuum leak cause the car to idle low, if not stall out? It's normal for engines to add more fuel when the coolant temperature is really low in the winter, so I think idling high when cold is fine as long as it comes back down to around 700 when it reaches normal operating temperature. Link to comment Share on other sites More sharing options...
