taylormac1993 Posted February 1, 2015 Share Posted February 1, 2015 Backstory: i lost my fuel pump after a 4eat to 5mt swap a little while back. Replaced the pump and filter, still nothing. Checked fuses and relays, still nothing. My fix was a hotwire on a switch to the pump. The switch died shortly thereafter, so I used the fuel pump relay and hooked the relay up to the existing wiring with a fuse and heavier duty switch. I basically redid the stock wiring on a switch. So my problem here is the element of human error. If i leave the switch on the pump stays running. Sure I could just run an accessory wire instead of a hotwire, but if i did that i would have to clean up all the wires i have coming from my accessories. What i want to do is hook up a chime of some kind to the switch, which is simple enough other than finding an aftermarket chime module. The question i have about all this is how do i get the chime to shut off while the engine is running? I was thinking about hijacking the existing door chime wires, but i want to keep the door chime because it has saved my butt a few times. I also dont want them both to be on the same chime. Tl;dr: any way to hook up a circuit that will be off only when the engine is running? Thanks guys. Link to comment Share on other sites More sharing options...
taylormac1993 Posted February 3, 2015 Author Share Posted February 3, 2015 Nobody? Im having a hard time even finding a chime or alarm module that wasnt made for security... Link to comment Share on other sites More sharing options...
corlon Posted February 9, 2015 Share Posted February 9, 2015 maybe? pm me if you want details on gow to install for your application. http://mgaguru.com/mgtech/electric/et245.htm http://www.radioshack.com/mini-12vdc-electric-buzzer/2730055.html Link to comment Share on other sites More sharing options...
