AJNelson01 Posted January 21, 2014 Share Posted January 21, 2014 Hello I have an 05 Legacy GT and the power steering will catch when I go to turn and press the gas at the same time. The car has 127K miles and runs great besides the steering. After the car has been warmed up for while it's better but still has a catch. Any ideas of what is wrong?? Link to comment Share on other sites More sharing options...
ras06LGT Posted January 22, 2014 Share Posted January 22, 2014 Is it a physical catch (like the wheel won't turn) or just a temporary loss of assist? If it's the latter, try bleeding the system. You might have air getting in. Search 'power steering o-ring fix'. Link to comment Share on other sites More sharing options...
AJNelson01 Posted January 23, 2014 Author Share Posted January 23, 2014 Is it a physical catch (like the wheel won't turn) or just a temporary loss of assist? If it's the latter, try bleeding the system. You might have air getting in. Search 'power steering o-ring fix'. When i try to turn there will be a point where the wheel won't turn past a certain point and the wheels will stop at that point also. It sometimes gets me into some accidents. Most of the time this will occur when I accelerate while turning. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 30, 2014 Share Posted January 30, 2014 There are some PS threads in the 4th gen forum. check them out. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
