mad99 Posted October 14, 2011 Share Posted October 14, 2011 I recently purchased a set of four wheels and tires from TireRack. I just hit a large rock on a city street and it caused a sidewall bulge in the right rear tire, ruining it. I still have to check the other tires more carefully. The tires only have 4077 miles on them. Tires are Dunlop SP Sport Maxx TT XL, pretty soft as they are max performance summer tires. My question is, how many new tires do I have to buy? One, or two, or four? I know it can damage the drivetrain (differentials) to use tires of slightly different diameters, but how much wear is enough to cause the diameter to change that much? The miles are mostly highway driving, but some spirited driving too. I have a second question that you might have experience with: Is there a good way to file a complaint with party that left the rock on the road? I went back and found the rock, and it came from a state construction project right around the corner. Link to comment Share on other sites More sharing options...
oldskoolbiker Posted October 14, 2011 Share Posted October 14, 2011 Measure the tread depth on your existing tires, call tirerack and have them shave it to match the other tires. That's what I did when I blew a tire on a curb. they charge you like $25 to shave the tire. Link to comment Share on other sites More sharing options...
nightspeed98 Posted October 14, 2011 Share Posted October 14, 2011 They shave tires? I just got the opposite tire few times and All is good. Link to comment Share on other sites More sharing options...
f1anatic Posted October 14, 2011 Share Posted October 14, 2011 ^ I pity your diffs. Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 14, 2011 Share Posted October 14, 2011 Tire Rack can only shave in 2/32 increments I think. Check tread depth and call them. As for complaining, you can contact the state's public service department and file a claim. There is a chance they will reimburse you for the damage if you have adequate proof. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
mad99 Posted October 15, 2011 Author Share Posted October 15, 2011 Thanks everyone for the suggestions. TireRack suggested the tread depth should be within 2/32" of the other tires, and mentioned that they can shave them. So, I will measure the depth. Link to comment Share on other sites More sharing options...
mad99 Posted October 19, 2011 Author Share Posted October 19, 2011 Subaru says "All of the tires on your AWD Subaru must be within 1/4 of an inch of rolling circumference" https://www.subaru.com/my-subaru/faq-technical.html I measured the tread depth at 9/32, and it's 10/32 when new. This means the circumference changed by less than 0.2", so I will just buy one new tire. Link to comment Share on other sites More sharing options...
nightspeed98 Posted October 19, 2011 Share Posted October 19, 2011 ^ I pity your diffs. Tire tread was negligible. My diffs are safe. Went through enough potholes that all 4 tires are newly replaced. Link to comment Share on other sites More sharing options...
phyl0x Posted October 24, 2011 Share Posted October 24, 2011 @oldskoolbiker thank you so much for your post, you literally just saved me hundreds of dollars. have winter tires that were in not new but good shape, and one got a nasty bubble in from a pothole at the end of last winter. was thinking about buying 4 new tires, but will ask tirerack about shaving one down. Link to comment Share on other sites More sharing options...
