volodyalysak Posted December 1, 2012 Share Posted December 1, 2012 High idle, and there is vibrations when in gear with brake pedal pressed or at wery low speed and rpm 1100-1200. New shortblock, new sparkplugs, all new vacuum lines new LCA new ball joints, new CV Axles. Has anyone experienced that ? Just really annoying 146K on body, 400 miles on shortblock and other stuff that i mentioned. Thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted December 2, 2012 Share Posted December 2, 2012 Are all the connectors tight on everything. How old is the battery ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
volodyalysak Posted December 2, 2012 Author Share Posted December 2, 2012 Well, i didn't put engine back myself, so can't really tell, looks ok from far. Battery is 2 years old. i had low idle problem before, cleaned throttle plate and now my idle is smooth at 1000-1100 rpm, but those stupid vibrations drive me nuts, feels like i'm driving 20 year old honda..... I have Tactrix cable, i'm going to datalog tonight a bit, and then will see, maybe injectors clogged up or something else. Hard to diagnose for me Link to comment Share on other sites More sharing options...
iNVAR Posted December 2, 2012 Share Posted December 2, 2012 your idle should not be that high at idle. double check everything. perhaps you have an vacuum leak. Link to comment Share on other sites More sharing options...
volodyalysak Posted December 2, 2012 Author Share Posted December 2, 2012 I sprayed all vacuum tubes with brake cleaner , no leaks. Link to comment Share on other sites More sharing options...
iNVAR Posted December 2, 2012 Share Posted December 2, 2012 check all intake connections. your idle should be down around 750-850, unless your engine is super cold. Link to comment Share on other sites More sharing options...
babybluelgt Posted December 2, 2012 Share Posted December 2, 2012 When you checked for vacuum leaks did you check the T connector under the IC? Link to comment Share on other sites More sharing options...
volodyalysak Posted December 3, 2012 Author Share Posted December 3, 2012 Is there one ? I should check it Link to comment Share on other sites More sharing options...
babybluelgt Posted December 3, 2012 Share Posted December 3, 2012 Yep. I believe its blue. I would just recommend going to the autopart or hardware store and getting a barbed fitting as well as using zip ties because some people have major issues keeping these lines on. Link to comment Share on other sites More sharing options...
Rattsl Posted December 3, 2012 Share Posted December 3, 2012 It's like...you're having a high idle while most of us have super low idles. I swear mines in the 500 or 400 range. Link to comment Share on other sites More sharing options...
volodyalysak Posted December 3, 2012 Author Share Posted December 3, 2012 Yep, but i suspect it could be also because of new shortblock, 500 miles on it. I did some data logging tonight, here is link to tuning forum: http://legacygt.com/forums/showthread.php/rom-raider-logger-see-logs-and-dyno-197372.html Link to comment Share on other sites More sharing options...
