3 - 2.5 in adapter bolts
Mat_Mandangle
Any 3/8 bolt nut and washers from the hardware store will work.
You don't need the OEM bolts.
get the bolts about 2" long and get some large OD washers.
I have better luck not using the support bracket from the tranny.
Engine Build - Click Here
