bkv348 Posted January 12, 2015 Share Posted January 12, 2015 Does anybody get any grief from Subaru dealers for having modifications done to your cars? I only have a catless turbo back exhaust and a stage 2 tune but I'm still nervous on what they will say. Link to comment Share on other sites More sharing options...
ras06LGT Posted January 12, 2015 Share Posted January 12, 2015 What they will say when....? If you bring it in for warranty work? Link to comment Share on other sites More sharing options...
MrTris Posted January 12, 2015 Share Posted January 12, 2015 When you pass a dealership. . . . . Don't stop. Don't even go in. Don't acknowledge that it exists. Problem solved. Link to comment Share on other sites More sharing options...
bluesuby Posted January 12, 2015 Share Posted January 12, 2015 I can see a dealer refusing to do work on your car if the work is linked to modifications you've done which may be not in conformity with (example) emissions systems. However, as Tris points out, there are plenty of independent shops who can do the work, and it'll be less expensive and better. Link to comment Share on other sites More sharing options...
DavidInSeattle Posted January 12, 2015 Share Posted January 12, 2015 I took mine to the dealer for the brake line recall. Not a word was spoken, but they did notice a leak I was aware of (and had repaired elsewhere). I think Subaru dealer service departments are well aware that their cars get modded. I doubt they would touch anything not OEM, but if it is there for an unrelated issue, there is no reason for them not to work on your car. That said, I avoid dealers like the plague if at all possible. Link to comment Share on other sites More sharing options...
kyleap007 Posted January 12, 2015 Share Posted January 12, 2015 I believe ours to be the same dealership, was in for some control arm and bushing work, there was no mention of stage 2 parts or tune... But I'm assuming your going in for your boost leak issues? Link to comment Share on other sites More sharing options...
kyleap007 Posted January 12, 2015 Share Posted January 12, 2015 You're* Link to comment Share on other sites More sharing options...
Redslaya Posted January 12, 2015 Share Posted January 12, 2015 Most of the people who work at dealers around me all drive modded subarus and one dealer will even install your aftermarket parts. As long as the aftermarket parts are not the reason for something breaking, you will be fine. even if they are, and you are not trying to get warranty work done you should be good Link to comment Share on other sites More sharing options...
MrTris Posted January 12, 2015 Share Posted January 12, 2015 Most of the people who work at dealers around me all drive modded subarus and one dealer will even install your aftermarket parts. As long as the aftermarket parts are not the reason for something breaking, you will be fine. even if they are, and you are not trying to get warranty work done you should be good Which dealer? AFAIK and have been told as much by many SAs, they will not install parts you bring; and cannot install any non-OEM parts because they cannot be warrantied for either manufacturer defects, nor labor. Link to comment Share on other sites More sharing options...
bluesuby Posted January 13, 2015 Share Posted January 13, 2015 Which dealer? AFAIK and have been told as much by many SAs, they will not install parts you bring; and cannot install any non-OEM parts because they cannot be warrantied for either manufacturer defects, nor labor. Fred Beans sells and will install aftermarket parts. I would not expect anyone to install parts you bring in to the shop. Link to comment Share on other sites More sharing options...
