Refuge Posted December 20, 2010 Share Posted December 20, 2010 I saw the Subaru Legacy GT Oil Control Valve On fred beans. Has anyone swapped one out? I have a rough Idle and might need to do it Link to comment Share on other sites More sharing options...
rao Posted December 20, 2010 Share Posted December 20, 2010 Search "TGV" Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
joeb-z Posted May 31, 2014 Share Posted May 31, 2014 Search "TGV" Gee what a helpful post. Is that the Tran Gran Vitesse or did you mean the OCV. By the way, for those that actually need to change this on the passenger side, as in, if your turbo failed, you need to get a small pry bar and "move" the bracket in the way to remove it. Great Subaru engineering. Link to comment Share on other sites More sharing options...
JmP6889928 Posted May 31, 2014 Share Posted May 31, 2014 Subaru FSM states to remove the bracket. WE have decided in our infinite wisdom (along with about 7000 Subaru techs) that it's MUCH easier to simply pry the bracket out of the way. That's called innovation ! ! Link to comment Share on other sites More sharing options...
RallyMachine Posted May 31, 2014 Share Posted May 31, 2014 I'm not sure what sort of magical car gods graced me but I simply removed the front breather hose on the passenger side and was able to slip the old one out and the new one in by rotating the OCV bracket 90° away from the engine and then back to vertical as I inserted it... Edit: just realized holy mother of god bump Link to comment Share on other sites More sharing options...
Massautowerks Posted May 31, 2014 Share Posted May 31, 2014 No CEL with the rough idle? Usually you get a code when these valves fail. Link to comment Share on other sites More sharing options...
Bbc84 Posted May 31, 2014 Share Posted May 31, 2014 I'm not sure what sort of magical car gods graced me but I simply removed the front breather hose on the passenger side and was able to slip the old one out and the new one in by rotating the OCV bracket 90° away from the engine and then back to vertical as I inserted it... Edit: just realized holy mother of god bump Yup just pulled the hose and slide off by rotating it 90*. I did the swap in a parking lot after buying the pair from the dealer. Easier to change these than light bulbs. Link to comment Share on other sites More sharing options...
omegachad80 Posted March 12, 2015 Share Posted March 12, 2015 Thread revival. Bent the bracket out of the way and I can get the OCV to rotate 90 degrees but it will not come out. I tried tapping it lightly to no effect. Is there a trick to removal, because it is not simply sliding out? Link to comment Share on other sites More sharing options...
MrTris Posted March 12, 2015 Share Posted March 12, 2015 Don't be a pussy -- pull hard. It'll have a bit of a vacuum to it. Link to comment Share on other sites More sharing options...
omegachad80 Posted March 12, 2015 Share Posted March 12, 2015 Thanks man. I'm used to being rough on the Galant VR-4 but I tend to treat my Legacy like a sweet little princess. I'll put the nuts to it and see if she gives. Link to comment Share on other sites More sharing options...
MrTris Posted March 12, 2015 Share Posted March 12, 2015 Thanks man. I'm used to being rough on the Galant VR-4 but I tend to treat my Legacy like a sweet little princess. I'll put the nuts to it and see if she gives. I know what you mean -- I do, too. Sometimes you just have to beat on it. Relatedly, these cars love to be flogged from time to time, as well -- don't forget to give her some of that when you get done with the job - Link to comment Share on other sites More sharing options...
omegachad80 Posted March 12, 2015 Share Posted March 12, 2015 That part I don't fail to deliver on. She's Cobb stage 2 and has seen two track days at Laguna Seca. Performs way better at the limits than I expected. I should update my build info. Link to comment Share on other sites More sharing options...
Ryan2626 Posted March 31, 2015 Share Posted March 31, 2015 I'm going to be replacing my oil control valve just for maintenance precautions on my 08 legacy I'm fairly new to Subies so I was hoping if someone could point me in the direction of where the ovc is located Link to comment Share on other sites More sharing options...
gimpydingo Posted March 31, 2015 Share Posted March 31, 2015 I won't be a dick and say to search, but you should search. http://legacygt.com/forums/showthread.php/help-p0021-intake-camshaft-position-timing-over-advanced-18887.html?highlight=OCV Doesn't take much time. I used my hand to bend the bracket on the OCV on the passenger side. Was a little bit of a pain to get it bent back when I replaced, but I got it. Mine looked good. I just cleaned with WD and moved the valve up and down to get some of the WD in the solenoid. Got the gunk out of there. Link to comment Share on other sites More sharing options...
MrTris Posted March 31, 2015 Share Posted March 31, 2015 Here, how about this? There are two, and they're in identical places on the head, just near the valve cover. Lower center, right above the valve cover in this picture. Link to comment Share on other sites More sharing options...
Ryan2626 Posted March 31, 2015 Share Posted March 31, 2015 Thanks guys greatly appreciated Link to comment Share on other sites More sharing options...
omegachad80 Posted April 1, 2015 Share Posted April 1, 2015 I won't be a dick and say to search, but you should search. http://legacygt.com/forums/showthread.php/help-p0021-intake-camshaft-position-timing-over-advanced-18887.html?highlight=OCV Doesn't take much time. I used my hand to bend the bracket on the OCV on the passenger side. Was a little bit of a pain to get it bent back when I replaced, but I got it. Mine looked good. I just cleaned with WD and moved the valve up and down to get some of the WD in the solenoid. Got the gunk out of there. The forum necessity, telling someone asking for advice to search. Where's the value added in such a statement? I read just about every thread on the subject. Passenger side came out without issue. Driver side was more of a pain. It was completely seized. I used a small pry bar and rubber mallet to tap it out of place with increasing force as it wouldn't budge. The larger section of the OCV slid out, but the narrow section remained lodged and sheered off. I then used a pick to remove the spring and rubber gasket that were easily accessible. I used a very low heat torch to heat the metal tube very carefully (after of course removing all sensitive plastics, etc. away from the immediate area). I then used some very narrow needle nose pliers to remove the remaining half. After ensuring the old OCV was completely removed, I installed the new unit without issue. Certainly an easy task when this is not the case. Car has 87k miles on it. Not a very fun time when something gets seized in such a relatively inaccessible location. Link to comment Share on other sites More sharing options...
gimpydingo Posted April 1, 2015 Share Posted April 1, 2015 The forum necessity, telling someone asking for advice to search. Where's the value added in such a statement? I read just about every thread on the subject. Passenger side came out without issue. Driver side was more of a pain. It was completely seized. I used a small pry bar and rubber mallet to tap it out of place with increasing force as it wouldn't budge. The larger section of the OCV slid out, but the narrow section remained lodged and sheered off. I then used a pick to remove the spring and rubber gasket that were easily accessible. I used a very low heat torch to heat the metal tube very carefully (after of course removing all sensitive plastics, etc. away from the immediate area). I then used some very narrow needle nose pliers to remove the remaining half. After ensuring the old OCV was completely removed, I installed the new unit without issue. Certainly an easy task when this is not the case. Car has 87k miles on it. Not a very fun time when something gets seized in such a relatively inaccessible location. Another Bay Area LGT and a Spec B. NICE!! Hopefully you didn't buy from Capitol Mitsubishi or Stevens Creek Subaru. The reason being is when something is posted and asked many times, why ask again/open a new thread? It just adds to confusion and not being able to find the information you need easily. You don't even need to search the forums, use Google, it can be your friend. I still gave the answer, I know it can be tough to find what you want. I'm sure you are aware other forums would warn people and then ban for something this simple. YAY the interwebz. Sucks about your OVC. The pass side is a pain. Did the rubber melt or something? Wonder why it was so wedged in there. How did it look besides being torn apart? Mine were looking good at 85k. Link to comment Share on other sites More sharing options...
omegachad80 Posted April 2, 2015 Share Posted April 2, 2015 No idea why it was so stuck. Forum searching never revealed any solutions to dealing with completely stuck OCVs. Plenty of great info out there, but nothing to deal with that issue. When it broke, I was completely winging it in my attempt to remove the remaining section. My experience, although unique, could still make a decent amendment to a sticky under the "shit went wrong" appendix. I've also had the car for 5 years now and bought it back east in the DC area. Damn thing has been a gem as long as I've owned it. Link to comment Share on other sites More sharing options...
iNfEk Posted February 6, 2019 Share Posted February 6, 2019 Back from the dead. Been dealing with a randomly dying issue on a 2005 LGT 5MT. new engine block and service a while ago and got the engine tuned via open source. Shortly after notice that the engine would die and I would perform a throttle body reset and it seemed to be good for a while. Randomly the car would die when coming to a stop in traffic. No CEL associated with it. I looked up oil control valve and it looks like this is this is for the AVCS? I now have an AP3 on it and had the tuner copy over the map from OS to my AP format and the idle got better but I still get the random dying out. I assume it could be a vacuum leak but if it’s a sticky OCV how do I know which one? Link to comment Share on other sites More sharing options...
BoozeRS05 Posted February 13, 2019 Share Posted February 13, 2019 With your Cobb AP you should be able to log the AVCS/OCV cycles for each side. If you see one not operating in sync with the other that's likely your culprit. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
Berge56 Posted February 19, 2019 Share Posted February 19, 2019 +1. I recently changed the OCV's on my car for stalling at stops and random idle issues. Replacing both OCV's appeared to have solved my problem. Link to comment Share on other sites More sharing options...
