bmononana Posted August 1, 2008 Share Posted August 1, 2008 when my car is idling and i push the throttle so it settles at 1500 RPM i get this terrible shudder, or shaking, the shifter shakes back and forth about a half an inch or an inch and I can feel the shaking through the clutch and gas pedals. in higher RPMs it goes away - probably being masked by the increased engine vibration. I figured it was a spark plug/wire issue - any other thoughts? Link to comment Share on other sites More sharing options...
SpawnGT Posted August 1, 2008 Share Posted August 1, 2008 subscribed. similair issue every once in a while. Link to comment Share on other sites More sharing options...
bmononana Posted August 1, 2008 Author Share Posted August 1, 2008 subscribed. similair issue every once in a while. Does it come and go? I've had a problem like this with one of my cars in the past - but I don't want this to escalate. i.e. if the vibration is messing up other components. Link to comment Share on other sites More sharing options...
SpawnGT Posted August 1, 2008 Share Posted August 1, 2008 well to be honest the last time I felt it, it was last night in the parking lot. the car was off for 12hrs...turned the car on, it idled fine for like 5 minutes a quick rough idle/shudder and then back to normal. the time before thAt probably a month ago. Link to comment Share on other sites More sharing options...
bmononana Posted August 1, 2008 Author Share Posted August 1, 2008 thats a good point - I haven't tried to get the shudder after I have driven around - i first noticed it when i was showing the car to someone and slowly revving the engine slowly up to 6-7K the car had been driving less than an hour ago however. I'll check it out after my drive home tonight. thx Link to comment Share on other sites More sharing options...
fishbone Posted August 4, 2008 Share Posted August 4, 2008 It's normal, that's what the Boxer acts like when you're at low revs in a high gear and you're overloading the engine, IE it's got no grunt. You don't feel it in an inline 4 cylinder because you don't have pistons slapping sideways. Mine does it too. Link to comment Share on other sites More sharing options...
bmononana Posted August 4, 2008 Author Share Posted August 4, 2008 It's normal, that's what the Boxer acts like when you're at low revs in a high gear and you're overloading the engine I wasn't in a high gear though - i was at a standstill in neutral and it was doing it... still normal? thanks for the input! Link to comment Share on other sites More sharing options...
fishbone Posted August 4, 2008 Share Posted August 4, 2008 Yes, at idle the boxer will sometimes shudder. That being said, not ALL shudder is normal. As long as it's not doing it often, IE every second and as long as it's not severe, it's normal. Link to comment Share on other sites More sharing options...
GTTuner Posted August 4, 2008 Share Posted August 4, 2008 Mine has done that since new, more dependent on engine temp in my case. Link to comment Share on other sites More sharing options...
spyguy Posted August 4, 2008 Share Posted August 4, 2008 +1 for mine as well, happened probably a handful of times. Can't recreate it.. Link to comment Share on other sites More sharing options...
imstillatwork Posted August 4, 2008 Share Posted August 4, 2008 yeah, sounds normal. pretty rough engines i think. If you're not used to them you notice every little shake. Link to comment Share on other sites More sharing options...
itsme Posted August 5, 2008 Share Posted August 5, 2008 I get it from time to time. I think it's just the flat 4 idle. Remeber they don't have balance shaft and balance themselves. At low rpms they don't shake like a inline 4s they rock. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
bmononana Posted August 5, 2008 Author Share Posted August 5, 2008 OK - thanks for all the input. Link to comment Share on other sites More sharing options...
