lgtvf52 Posted August 20, 2013 Share Posted August 20, 2013 hey guys im sure this topic has been dicussed but i cant seem to find it anywhere.. Since the motor is pulled from the car now and before i put everything back on the new motor I will be going stage 2 and I will be getting the car tuned and the PO of my car had the clutch replaced with what I believe is a stock clutch? (Sachs) 10k miles ago. I want to know if I have to get a better clutch or will this one hold up? If i have to get a replacement what do you guys suggest that wont break the bank (the motor build is already hurting the wallet) the car is going to be getting a stock STi EJ257 shortblock and stock 05 lgt heads, vf52 w/ billet compressor wheel and tuned at 18psi. Thanks Link to comment Share on other sites More sharing options...
idiot4hire Posted August 21, 2013 Share Posted August 21, 2013 Check and see if you have the dual mass fly wheel or not. The only clutch that works with the dual mass is the oem clutch and spec clutches. I would look to upgrade since you have a vf52. I use a clutch masters fx350 with a wrx fly wheel and I love it. Infamous recommended I try comp clutch that comes as a package with the flywheel. I also had a spec with the light weight fly wheel the clutch was fine but I wouldn't recommend the lwfw for dd use. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 21, 2013 Share Posted August 21, 2013 Get a single mass FW, I enjoy my Spec 2 clutch with my vf52 at 21psi. It has a little heavier pedal then stock. I would not do a LWFW again. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
lgtvf52 Posted August 21, 2013 Author Share Posted August 21, 2013 What year wrx does the flywheel fit? Or does it not matter Sent from my SPH-L710 using Tapatalk 2 Link to comment Share on other sites More sharing options...
JermTheElf Posted August 21, 2013 Share Posted August 21, 2013 07+ I believe. I have an Exedy Stage 1 clutch for the WRX SMFW for sale for $200 shipped. I've had it for 8 months and it only has 12,000 miles. As you can see 8 months and 12,000 miles; highway miles. No track time etc. etc. Link to comment Share on other sites More sharing options...
lgtvf52 Posted August 21, 2013 Author Share Posted August 21, 2013 PM'd Link to comment Share on other sites More sharing options...
