pxer Posted December 8, 2011 Share Posted December 8, 2011 Hello All, Just received my Turbo XS DP and CP. Very nice finish, and huge. Although I am looking at the mounting hole location on the CP (that connects to the rear stock pipe) and they are not your standard width. The flange is 3 inch but the holes are spaced about 5 inches apart. The included gasket as well as the Grimmspeed adpater I got both have 4 inches between the mounting holes. I took a quick measurment on the stock mountin loaction (where the spring loaded bolts are) and it appears to be 4 inches across for the mounting holes (5 inches total). If anyone has done this please provide comment, or please provide your opinion. I am not sure if I measured wrong and if not should I just bore out the holes on the CP so it will line up. Here are a few pics of my dilemma. 1 -DP with standard gasket next to oversized CP 2 - Standard dimension of pipe 3 - Oversized dimension of CP Link to comment Share on other sites More sharing options...
