Most modded / fastest OB?
  • Replies 215
  • Created
  • Last Reply
You can look at your car as a Legacy with a unique high power/terrible suspension combination
Throw the deadly suspension away and make it a real car. So much more fun.
I don't mean anything bad, just pointing you missing a lot compared to LGT
You could lower it and make the geometry, um, interesting....
06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest.
once upon a time there was a member named chuckatoo (sp). He was way ahead of the game about a year ago.
that project was scrapped and the car parted out.
'scoobydude' has his car at Stg II with headers coming and chucktoo's ZEAL's, Cusco swaybars, P1's with 245 summer tires, and a few other things. I don't know whether by 'most modded' you mean most money spent, most parts bought, fastest or best handling but I'd say you and Steve are about on par (with Drewster somewhere in the mix too).
Is our suspension really that bad?? What significant minor changes could we make to the suspension without lowering it?
dave
dave
it is that bad for driving more than 7/10's. That being said...most OBXT owners didn't buy for the handling on-road, but for the ground clearance. To be honest....I'd be better off with an OBXT for what I'd like to use it for.
heheh....you're wrong man. I've seen more of that type east in MD than west in WV ;) Proof (Odenton, MD back in 2003):
http://i4.photobucket.com/albums/y124/PatagonianGT/0abc.jpg
I sold my CRX and my Jeep for the LGT. The OBXT and new Mini would be worthy replacements (since most offroading was fireroads and car-camping). A lowered LGT wagon loses it's utility. :(
He's not comparing his to a gt. Only asking who has the most modded/fastest OBX.
ya what ever happened to chuckatoo??
his wife gave him and ultimatum and he had to sell the car. The shop that had it took him for a ride and he had to cut his losses and moved on. Sad really....a ton of $$$ invested and walked away with pennies on the dollar. If only the shop had delivered on it's promises...there'd be a wicked OBXT out there. ;)
damn, that suxs.
whoa! stop the presses. It was hardly about that. the man had another toy being built.... a Factory Five Racing Cobra. The OBXT was languishing in the shop and the man was lied to apparently by that shop about progress and an end date. His wife's patience had run out....that's all.
2005 OBXT ~15K miles
Ksport Coilovers
Rotora BBK front and rear
SSR Competitions 18x8.5 w\ 245/45/18 Falken 451
Crucial P&P&C header
Perrin ceramic coated uppipe
Perrin Lightened crank pulley
Perrin TMIC
Stromung ceramic coated TBE
Kartboy shortshifter w\front and rear bushings
PE850cc injectors
Walbro 255 fuel pump
Accessport
I'm only waiting on a DB20G at this point, also thinking about the MTS RPS clutch.
Powertrain:
260awhp 301awtq
AP stg 2+ (Agile Protuned)
AVO Wastegate Actuator
COBB HFC Downpipe
COBB Uppipe
Hogzaust Performance Exhaust
Perrin Filter
IC sprayer
Airbox resonantor removed
Mobil1
Drivetrain:
Kartboy short shifter
Kartboy F&R shifter bushings
Audio:
Cleansweep audio processor
RoadyXT XM Satalite Radio on PanaVise Mount
Polk components up front
Polk coaxials rear
Polk GNX10 Subwoofer
Custom built stealth sub box
Profile AP740 amp (60x4)
Profile California Jam J200.2 (180x1)
Dynamat all around
http://www.crutchfieldadvisor.com/cu...r_outback.html
Interior:
Defi D-gauge Boost Gauge
Map lights wired to dome light
Hardwired Passport X50
MOMO shift knob
Exterior:
DRL disabled
Cleared headlights
Sylvania Silverstar turn signal lamps
'Tap To Turn' Turn signal mod
Red Vinyl overlays on tail lights
Fog Light Mod
PIAA Super Silicone Wiper Blades
Debadged, butt is naked
Suspension:
JDM 20mm Rear Sway Bar
Wheels / Tires:
Dunlop Winter Sport M3's (Died)
OZ Superleggeras in Gold 18x8
Toyo T1R's 245/45-R18
Tamper Resistant Tire Valve Caps with Subaru Logo
Brakes:
Technafit SS Brake Lines
Super Blue Racing Brake Fluid
Edit: Updated list for newcomers
The Numbers
13.69sec @ 102.84mph (5500' Above Sea Level)
390 WTQ (E85)
361 WHP (E85)
??? WTQ (91 Octane Gasoline)
??? WHP (91 Octane Gasonline)
Powertrain
Tuned by TheBoostCreep
Open ECU w/ Launch Control
STi EJ255 Case Halves
STi Crankshaft
ARP Studs
Eagle Rods
Cosworth 9.2:1 CR pistons
Cosworth Rings
Cosworth Main Bearings
Cosworth Rod Bearings
Cosworth Head Gaskets
NGK Iridium 1-Step Colder Spark Plugs
Custom Oil Catch Can
Die Hard Gold Battery
Subaru Block Heater
Turbo / Intake
GT2871r .86AR Disco Potato
WBR FMIC
Super Rupair 3-port Boost Control Solenoid
TGV Delete
L&E Fabrications Cold Air Intake
Custom Intercooler Sprayer
Re-circed BOV
Exhaust
L&E Fabrications Up Pipe
L&E Fabrications De-Catted Down Pipe
3" Custom Exhaust (Boulder Muffler)
Grimmspeed Double Thick UP Gasket
Fueling
Injector Dynamics Bosch 1000cc Injectors
Side Feed to Top Feed Fuel Rail Conversion
PLtek Walbro 255 L/hr Fuel Pump
Drivetrain
ACT 06' WRX Clutch Conversion
06 WRX Flywheel
STi Tranny Mount
Whiteline Tranny Bushings Race
STi Engine Mounts
STi Pitch Stopper
Subaru Extra-S Gear Oil
Audio
SkyFi3 XM Satalite Radio on PanaVise Mount
Polk coaxials rear
Dynamat all around
Interior
Map lights wired to Dome Light
Hardwired Passport X50 - Blue
MOMO shift knob
20% Tint on all windows
Exterior
DRL disabled
Cleared headlights
Sylvania Silverstar Turn Signal Lamps
'Tap To Turn' Turn Signal Mod
Red Vinyl overlays on Tail Lights
Fog Light Mod
Truck Air Horns
PIAA Forza Hybrid Super Silicone
'E85 Flex Fuel' Badge
Suspension
SuperPro Front Lower Control Arm Bushings
Wheels / Tires
ASA JH3 17x7.5 Wraped in Dunlop WinterSport M3 225/55-R17
OZ Superleggeras in Gold 18x8 Wraped in Yokohama Advan S.4 245/45-R18
Brakes
Brembo Grand Turismo Front BBK w/ Hawk HPS pads
LGT Rear calipers w/ Racing Brake BRK w/ Endless SS-M pads
Carbotech XP8(rear) and XP10(front) track pads
(Updated 8/22/17)
2005 Outback FMT
Running on Electrons
Powertrain:
260awhp 301awtq
COBB HFC Downpipe
COBB Uppipe
Perrin Filter
IC sprayer
Mobil1
Drivetrain:
Audio:
Polk coaxials rear
Dynamat all around
Interior:
MOMO shift knob
Exterior:
DRL disabled
Cleared headlights
Fog Light Mod
Suspension:
Wheels / Tires:
Brakes:
With all those mods how about at least a 1/4 mile time....? It would be harder for you to give us meaningful handling information.
last time i did a 1/4 I was stg 1.... 14.012 @ 97mph
now I should hit a low 13 if not breaking the 12 mark....but my clutch would never hold anyways... at least not the launch. My clutch slipped in gear for the first time today. Looking at clutch options at the moment.
As far as handling goes...that JDM sway and 245/45-18's really make a huge difference. I won an AutoX in the SM class about a month ago.
(Updated 8/22/17)
2005 Outback FMT
