SamWise Posted October 31, 2012 Share Posted October 31, 2012 Hi guys, not very mechanically inclined and I have been having issues with the steering on my 06 Legacy gt wagon. It seems to be stiff at times and sometimes squeals when I am using full turn radius. Is this due to power steering pump? I checked the ps fluid and it was all good. Your comments and assistance are appreciated. Link to comment Share on other sites More sharing options...
Mill Posted October 31, 2012 Share Posted October 31, 2012 Squealing would be from the power steering belt. Chances are if the car is high mileage it could be worn out. I suppose it is a possibility that the pump could be on its way out. I would try replacing the belt and go from there. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 31, 2012 Share Posted October 31, 2012 X2 for what he said. There have ben a few guys here with bad PS pumps. Mine has been fine, but I'm one of the ones that has had to replace the steering rack because it was leaking. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
SamWise Posted October 31, 2012 Author Share Posted October 31, 2012 Thanks guys. I really appreciate the information. Link to comment Share on other sites More sharing options...
Rooster Posted October 31, 2012 Share Posted October 31, 2012 Squealing only at full lock isn't too uncommon, depending how bad it is. Not going to be a belt if it only does it at certain steering angles. If it is particularly loud, more than just a loud hum, probably going to need to replace the pump. Link to comment Share on other sites More sharing options...
V8Bait Posted October 31, 2012 Share Posted October 31, 2012 I doubt its the pump. Replace the belt like others said and you should be golden. If it still squeals after replacing the belt make sure you tightened it enough before assuming its the pump. Link to comment Share on other sites More sharing options...
