IGW Posted February 25, 2014 Share Posted February 25, 2014 What are the downfalls of running a catless downpipe? Link to comment Share on other sites More sharing options...
TheBlackPearl Posted February 26, 2014 Share Posted February 26, 2014 I've always heard that it's the smell, but I can smell my catted dp after a pull too so? Self proclaimed PNW Craiglist find of the day Champion, April 2014. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted February 26, 2014 Share Posted February 26, 2014 some people have boost creep from the lack of back pressure Link to comment Share on other sites More sharing options...
robinlsb Posted February 26, 2014 Share Posted February 26, 2014 None:) Never had boost creep, but it requires a tune, plus you may fail inspection. Hi flow cat or gutted cat is the way to go. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
IGW Posted February 26, 2014 Author Share Posted February 26, 2014 will it work w a AP STAGE 2 tune? Link to comment Share on other sites More sharing options...
Brett Posted February 26, 2014 Share Posted February 26, 2014 no problems, and yes, it works with the AP map. Link to comment Share on other sites More sharing options...
robinlsb Posted February 26, 2014 Share Posted February 26, 2014 will it work w a AP STAGE 2 tune? I used a COBB catted down pipe and a Cobb non cat up .pipe and a Cobb stage II tune. That was 100k miles ago. No problems, but then I don't race the Subie. The car has the original turbo. I just change the oil (dino) every 2000 miles. Checked the turbo screen at the last change, clean as a whistle. I know I have left power on the table, but then I kinda like longevity:) The most important thing on these motors is to look at the torque curve. Just because you can get 7000 rpm, is no reason to do it "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
IGW Posted February 26, 2014 Author Share Posted February 26, 2014 my car is babied I have 10k on the new EJ257 shortblock and rebuilt heads. I love my LGT!! Link to comment Share on other sites More sharing options...
IGW Posted February 27, 2014 Author Share Posted February 27, 2014 What about the difference between a divorced/non-divorced pipe? Should the divorced be use on a stock turbo? Link to comment Share on other sites More sharing options...
PtPixel Posted February 27, 2014 Share Posted February 27, 2014 I have catless. No complaints here. Since there is more fuel making it out the exhausts then you can get some afterfire (Not always a bad thing ). Also can get some pops and crackles from downshifts, again nothing to complain about. I've never noticed the smell. I'm sure if you do if you get beside the exhaust after driving but otherwise nothing. What about the difference between a divorced/non-divorced pipe? Should the divorced be use on a stock turbo? A bit of debate goes on about this. Some say divorced separates the gasses coming out of the wastegate from hitting the gasses coming out of the turbo. This is supposed to lead to less back pressure and better performance. I don't know the process design behind cars that well but I'm a process engineer and I'd say there would be next to no difference between having divorced or not. Any back pressure created by the wastegate gasses would be well driven downstream by the turbo gasses. You'd need some massive flows from the wastegate to get any back pressure. I suspect it's just a marketing gimmick to make one product seem better than others. Link to comment Share on other sites More sharing options...
PtPixel Posted February 27, 2014 Share Posted February 27, 2014 some people have boost creep from the lack of back pressure Never had this. The less back pressure behind a turbo the better. N/A cars benefit from back pressure as it can help "scavenge" the gasses out of the piston chambers. Forced induction cars don't need this. Link to comment Share on other sites More sharing options...
IGW Posted February 27, 2014 Author Share Posted February 27, 2014 You would think thats is true! I wasnt sure if the exh from the turbo would have any neg affect on the air being released from the wastegate Link to comment Share on other sites More sharing options...
PtPixel Posted February 27, 2014 Share Posted February 27, 2014 The velocity of the gas coming out of the turbo will create a vacuum effect for the gasses coming out of the wastegate. Any gas from the wastegate will just get sucked into that stream of gasses whether or not it's divorced. Just changes how close this happens to the turbo. Link to comment Share on other sites More sharing options...
IGW Posted February 27, 2014 Author Share Posted February 27, 2014 Thanks for your advice... Link to comment Share on other sites More sharing options...
chimera Posted February 27, 2014 Share Posted February 27, 2014 Originally Posted by Nightmaresmk http://legacygt.com/forums/skynetim/buttons/viewpost.gif some people have boost creep from the lack of back pressure Boost creep from lack of back pressure? Then surely that would be a tuning issue. Wastegate controls boost, period. Link to comment Share on other sites More sharing options...
Shik Posted March 2, 2014 Share Posted March 2, 2014 [/i] Boost creep from lack of back pressure? Then surely that would be a tuning issue. Wastegate controls boost, period. There are tons of info on boost creep, but to make it super simple: When the wastegate is fully open, it will flow "X" amount of exhaust through it and around the turbine, which in turn limits how fast the turbine spins, which in turn limits how fast the compressor spins, which in turn limits boost. The problem occurs when the ECU/boost solenoid reaches the target max boost number and the wastegate is fully open, thus bypassing as much exhaust around the turbine as the stock system is physically capable of doing. However, because of a much free'er flowing exhaust due to being catless, it is possible for the engine to breath that much better that the amount of exhaust being produced is more than the "X" amount that the wastegate can bypass around the turbine. This extra exhaust continues to pass through the turbine, which in turn causes it to spin faster, thus the compressor spins faster, thus making more boost that continues to "creep" higher and higher, totally uncontrolled. So, boost creep is based off of physical limitations of the factory internal wastegate. Once the boost solenoid is at 0 wastegate duty cycle(wide open), and your boost is still climbing, tuning will not help at that point. So yes the wastegate does control the boost...until the wastegate can't control the boost no more FWIW, I had 3" catless exhausts on my old Legacy Sport Sedan as well as my old WRX and never had a boost creep problem at stock or near stock boost levels. Link to comment Share on other sites More sharing options...
PtPixel Posted March 2, 2014 Share Posted March 2, 2014 I think that would be a tuning issue. Any turbocharged system is limited by the compressor efficiency - the compressor will reach a limit at which it cannot pressurise any more air through the system, and because a piston engine acts as a batch kind of system them there is a limit at which the exhaust gas volumes will reach. The only time you would expect to see more exhaust gasses than the wastegate could handle would be if the tuned WGDC was not designed for the exhaust gasses (ECU controlled as you mentioned), or there was a mechanical issue with the wastegate. Any turbocharger system should be engineered to the compressor limits. Boost creep will happen with an oversized turbocharger but the bigger, resulting, problem would be compressor surge. The lack of back pressure on a turbo will help mitigate any boost creep by allowing freer flowing gasses through the wastegate allowing it to do its job. A lesser pressure differential on either side of the wastegate will restrict it further. Link to comment Share on other sites More sharing options...
chimera Posted March 2, 2014 Share Posted March 2, 2014 So yes the wastegate does control the boost...until the wastegate can't control the boost no more Most definitely... replacing the wastegate or porting the existing would suffice in this aspect... still down to the wastegate though Link to comment Share on other sites More sharing options...
micha3lchu Posted March 2, 2014 Share Posted March 2, 2014 For the smell alone, I'm a huge advocate of running a catted system. Not to mention potentially throwing codes. Link to comment Share on other sites More sharing options...
