m_dogg Posted March 16, 2012 Share Posted March 16, 2012 I'm sure I'll be fine but want to double check before I pull the trigger. 8" wide rims fit the wheel well without rubbing, correct? Car is stock. Thanks! Link to comment Share on other sites More sharing options...
scoobydoobie Posted March 16, 2012 Share Posted March 16, 2012 Need more information. What offset are the wheels you're looking at? And what size tire do you plan on running? Link to comment Share on other sites More sharing options...
m_dogg Posted March 16, 2012 Author Share Posted March 16, 2012 From TireRack: Size: 17x8Offset: +45mmBackspacing: 6.25"Bolt Pattern: 5-100Rec. Tire Size: 215/45-17 Link to comment Share on other sites More sharing options...
scoobydoobie Posted March 16, 2012 Share Posted March 16, 2012 You will be fine. However I'd run a 225/45 or 235 with a wheel that's 8 inches wide. Also forgot to ask, what suspension? I run a 225/45/17 on my 17x8 +47. Lowered on Bilsteins/Pinks. Want to try and fit 245/40/17 next. Link to comment Share on other sites More sharing options...
whitetiger Posted March 16, 2012 Share Posted March 16, 2012 if you dont mind rolling fenders, you can do a 245/40/17 on a17x8 +45 no problems Link to comment Share on other sites More sharing options...
boxkita Posted March 17, 2012 Share Posted March 17, 2012 if you dont mind rolling fenders, you can do a 245/40/17 on a17x8 +45 no problems If you have good camber (2+ degrees), you'll need about 3/4 to 1 inch of clearance depending on low you are. If you have stock camber, you'll need more. With stock suspension on 05 wagon, a 245/40/17 R1 was 2 inches beyond the fender even with the tightest et I could get (would have been a custom rim). The same tire with bc coilovers and 2.5 degrees camber, the tire was still proud of the fender about 3/4 inch. You can also try something like this - http://www.japanparts.com/db/parts_detail.php?submit.x=32&submit.y=5&NUMBER=00027904&VOLUME=031-043-003&DEALER=1&CAR=6&MIDDLE=2&SMALL=11&MAKER=29&VOLKEY=&SEARCH_DEALER=1&SEARCH_CAR=6&SEARCH_MIDDLE=2&SEARCH_SMALL=11&SEARCH_MAKER=&SEARCH_VOLKEY=&SEARCH_page=2 Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
