Bicyclemech1 Posted June 14, 2013 Share Posted June 14, 2013 All the links that come up with a search have seemed to dry up. I am watching a couple first gen intakes on eBay. Should I just stick with one of those? I am not going to spend $200+ on a Weapon R. Link to comment Share on other sites More sharing options...
Zues Marine Posted June 14, 2013 Share Posted June 14, 2013 you need to find a 'ribbed' intake tube from a EJ18 or 22 - this is the tube that has the most effective velocity of all n/a tubes a 3" MAF adapter is going to be necessary from here you can do two things; remove the snorkus/ 'intake silencer' out of the fender and route the filter in it's place, or put a cone filter where the intake box was, right off the MAF the first option is going to give you colder air, but makes it way easier to pick up water/ other road stuff into the filter read this link to know what's going on with the voltage spike in the MAF Link to comment Share on other sites More sharing options...
Bicyclemech1 Posted June 14, 2013 Author Share Posted June 14, 2013 I am guessing the intake tube you refer to is the '96 and earlier non-resonator box type. I read the MAF/ Snorkus delete thread earlier and it did not offer a fix for the harmonic frequency problem as it applies to our second gen. It is a huge thread, please correct me if I missed it. Link to comment Share on other sites More sharing options...
