Diggs753 Posted October 5, 2007 Share Posted October 5, 2007 I just tried to install a set of perrin sway bars on my 07 OBXt the seem to be a little short and the end links are a couple of inches away from the holes on the bars.They are 22mm adjustables.Anyone else having issues with them? Link to comment Share on other sites More sharing options...
05Limited Posted October 5, 2007 Share Posted October 5, 2007 The outback uses a different sized swaybar, if I remember correctly - someone had the same problem installing the cobb bars on an outback, used washers or something to make it fit... Found it: http://legacygt.com/forums/showthread.php?t=38084&highlight=sway+cobb+outback look at post #4 Link to comment Share on other sites More sharing options...
Diggs753 Posted October 6, 2007 Author Share Posted October 6, 2007 Yeah I'm familiar with the Cobb issue but that is on the front bar this is the rear.The end links stop well short of the holes on the bar.I didn't have much time to install it but it went together failry easy and I doubt I miffed it fairly soldier proof.Anyways I'll keep searching. Link to comment Share on other sites More sharing options...
Boulderguy Posted October 6, 2007 Share Posted October 6, 2007 I had no problems installing on an 05 OB, so something's different. BTW, I tried both the Perrin & Cobb bars and the results were noticeably better with the Cobb bar. Also, ironically, found using the stock front bar felt better than using the matched pair (cobb or perrin). Link to comment Share on other sites More sharing options...
