rdhayward Posted April 27, 2013 Share Posted April 27, 2013 I just purchased a used Wilwood rear brake kit, No. 140-7006-D, which includes rear SS brake lines. Wilwood's website shows these parts (Kit No. 140-7006-D and Flexline Kit 220-7010I as only fitting Impreza/WRX models. What's needed to make this fit the rear of my '00 Legacy L Wagon with 16" OEM snowflake wheels? I'd like to know if I can use this rear kit, before I buy a front Willwood setup to match it. Oddly, Wilwood's website lists a front kit for my car, but no brake lines. Link to comment Share on other sites More sharing options...
Th3Franz Posted April 29, 2013 Share Posted April 29, 2013 does your car have rear discs? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
rdhayward Posted August 23, 2013 Author Share Posted August 23, 2013 I've figured out that it's necessary to convert the rear brakes from 190mm to 170mm parking brakes in order to fit the Wilwood kit. Here are the rear backing plates (for Impreza/Forester) modified by Austin Speed Shop. The outer dust shields had to be removed, and the caliper mounting points machined per Wilwood's instructions so their calipers will fit. Link to comment Share on other sites More sharing options...
rdhayward Posted August 24, 2013 Author Share Posted August 24, 2013 The white Wilwood lettering on my front calipers is already starting to flake off, less than two months after installing them. So I've decided to dress them down a bit with high-temp decal material. Here's what I did with the rear calipers yesterday. Link to comment Share on other sites More sharing options...
rdhayward Posted August 29, 2013 Author Share Posted August 29, 2013 I now have the rear suspension and brake parts needed to complete the project. The brakes consists of: * Wilwood DynaPro 140-7006-D kit (high temp black vinyl and gold "SUBARU" lettering on calipers) (rotor/hat assembly safety-wired) * Wilwood SS flex lines, new Subaru rubber lines * Impreza/Forester backing plates (dust shields removed, caliper mounts modified to fit Wilwood bracket) * 170mm parking brake shoes and hardware Link to comment Share on other sites More sharing options...
