Radiator issues
2005subie
And I bought my koyo replacement for under $100
lol, hence why i say set your budget and go from there
I guess another thing is what do you want to achieve? If you are not racing the car, no need for big core aftermarket replacements
No cutting needed, just trimming the top hose because it will hit the OEM fans.
Also if you have a 5EAT, which was my case, you will need to run an external ATF Cooler. For a MT this is not needed.
Mishimoto sells a fan with shroud that, from what I've read, performs better than the OEM fans.
You'll also need to trim the small hose from the top overflow tank to the radiator...no big deal. Mine was a bolt-in with no modifications or cutting. You'll need to buy another couple quarts of anti-freeze (or just get 3 gallons, use half now an the other 6 quarts in the future). I also like the drain plug on the Mishimoto. It's a real plug.
