AndrewZ Posted July 4, 2010 Share Posted July 4, 2010 The other day it was very hot in my car and I accidentally hit 3 on the disc changer as the car hit a bump in the road. While it was changing I pressed 5 to go back to the CD I was on. The CD changer kept making the same sound, like it was working but not getting anywhere, and eventually it wouldn't let me select CD and would only play the radio. I tried disconnecting the battery, it still makes no response when I press CD. I took off the covers on the player and have posted the pictures of the changer from the top. It looks like there is a jam going on. Before I break something, has anyone advice on how to fix this? I'd really, really appreciate any help. Kindly, Andrew Link to comment Share on other sites More sharing options...
AndrewZ Posted July 5, 2010 Author Share Posted July 5, 2010 Does anyone have a picture or know how the cds should look on the spindle? Link to comment Share on other sites More sharing options...
AndrewZ Posted July 5, 2010 Author Share Posted July 5, 2010 Peep the pictures http://legacygt.com/forums/attachment.php?attachmentid=87150&stc=1&d=1278371163 Should that CD be in that location? It has the same label as the top CD for reference Link to comment Share on other sites More sharing options...
LGT Dave Posted July 6, 2010 Share Posted July 6, 2010 Just doing a quick search, some people have used a small screwdriver to move the misaligned discs back in line with the others and said that works. I'm not sure if the one that you have pointed out is over there because that's where the CD lens is or if it really is out of place. Also, you may want to consider not using those vinyl CD-R's anymore. I've seen people get them jammed in CD players because that vinyl layer makes them a little bit thicker than a normal CD. Link to comment Share on other sites More sharing options...
AndrewZ Posted July 6, 2010 Author Share Posted July 6, 2010 Hey Dave, Thanks for responding. I've done a few searches but haven't found any advice on what it's supposed to look like from the start. I think you're right in regards to the vinyl cds, though Link to comment Share on other sites More sharing options...
C6Driver Posted July 6, 2010 Share Posted July 6, 2010 This is good to know. I have one disc I'll be removing because it's a disc I made of various music. If it' more likely to jam, it's history! Link to comment Share on other sites More sharing options...
leofski Posted July 6, 2010 Share Posted July 6, 2010 If you can't fix it, I have a P-201UH that I'd sell. Let me know. Link to comment Share on other sites More sharing options...
dr_sharp Posted July 7, 2010 Share Posted July 7, 2010 Andrew, this just happened to me a few weeks ago. Use a screwdriver to line them back up. Good luck! (I broke one of the cds in the changer, but that's a small price to pay compared to the price of the changer). lol Link to comment Share on other sites More sharing options...
dr_sharp Posted July 7, 2010 Share Posted July 7, 2010 This won't help you, but here is my thread: http://legacygt.com/forums/showthread.php/cd-changer-error-help-plz-140451.html?t=140451 Just line them up on the bottom spindle... the one on the opposite side of the pictures you took. Don't break your changer... remember, the disks are cheap. lol Link to comment Share on other sites More sharing options...
AndrewZ Posted July 7, 2010 Author Share Posted July 7, 2010 Once I believe I have it all aligned, how can I reset the stereo so it will try to switch to CD? Last time I put it back in the car it still does nothing when I hit CD Link to comment Share on other sites More sharing options...
dr_sharp Posted July 7, 2010 Share Posted July 7, 2010 That's not good. When you plug in the main white connector the cd player should make a bunch of noises as it shuffles discs. Mine stopped functioning when the jamb occured. But once I realigned the cds and plugged in the connector, it did make the noise. Are you sure they are all lined up on the main spindle? Also, something may have happened to the cd changing mechanism when you hit the bump. If that's the case, I don't know what to tell you. lol Link to comment Share on other sites More sharing options...
AndrewZ Posted July 8, 2010 Author Share Posted July 8, 2010 Are you sure that bottom CD shouldn't be where it is? When I try to move it, it springs back into place. It looks like there's a cord somewhere that's moving when I move it. It was in the process of changing CDs when it stopped working Link to comment Share on other sites More sharing options...
AndrewZ Posted July 8, 2010 Author Share Posted July 8, 2010 Well here's a cool picture http://legacygt.com/forums/attachment.php?attachmentid=87231&stc=1&d=1278558231 Does that look right? I took the changer out of the stereo and was able to pull back the arm that was binding it and get the CDs in place. I'm going to try it. I pulled out the other connector in the stereo to incase that might help get the stereo to recognize the CD function (yeah, right ). Crossing my fingers I have another question: http://legacygt.com/forums/attachment.php?attachmentid=87235&stc=1&d=1278559184 Where does the CD come out? Is that lined up right, the front? Link to comment Share on other sites More sharing options...
AndrewZ Posted July 8, 2010 Author Share Posted July 8, 2010 Please forum gods don't kill me for triple posting PROGRESS! I installed the player. The CD button still does nothing, but when I press and hold the eject button it flashes "CD EJECT ALL" or something to that tune. It wouldn't do that before. I'll investigate further tomorrow. Dr. Sharp, thanks for the encouragement; I'm not sure if it's going to work but I got this far riding on your feedback Link to comment Share on other sites More sharing options...
dr_sharp Posted July 8, 2010 Share Posted July 8, 2010 The first picture looks right. The cds are stored at a slight angle. Are all of the cds in little metal "sleeves" at the side of the case? If the one that seems to spring around isn't in a sleeve, then I'd guess it is stuck in limbo between one of these sleeves and it being ejected. And yes, the second picture is where the cds are ejected. If you could find a way to get the bottom cd to make its way out of this slot, I suspect you'll be in business. lol Link to comment Share on other sites More sharing options...
dr_sharp Posted July 8, 2010 Share Posted July 8, 2010 http://legacygt.com/forums/attachment.php?attachmentid=87231&stc=1&d=1278558231 I think the sleeves that I'm trying to describe are on the opposite side of this picture. lol Link to comment Share on other sites More sharing options...
AndrewZ Posted July 9, 2010 Author Share Posted July 9, 2010 I did think they were all in the sleeves. I didn't have much time today to play with it, but it still gives me that message when I hold the eject button. Its like it doesn't know it has any CDs in it, but pressing load says nothing. I haven't tried yet slipping a CD into the opening; tomorrow I'll try disconnecting the battery for a while again and perhaps there's a sensor that will wake it up if I try slipping in a CD? If you look at the last picture I posted it doesn't seem to me like the slot for the CD is exposed, as if it slid up? I don't know what it should look like Link to comment Share on other sites More sharing options...
AndrewZ Posted July 14, 2010 Author Share Posted July 14, 2010 I haven't had any luck yet. I'm going to try taking it out once more Sunday, if it doesn't work then just buying an FM modulator Link to comment Share on other sites More sharing options...
AndrewZ Posted July 23, 2010 Author Share Posted July 23, 2010 Still no luck! Any way to get it to realize it has CDs in it? Link to comment Share on other sites More sharing options...
