nismoz Posted August 11, 2008 Share Posted August 11, 2008 I am going to gut the OEM DP soon. I was wondering if I need to get a tune because of this? Also, I will soon receive the Tactrix Cable I ordered. Thanks in advance. Link to comment Share on other sites More sharing options...
atc5 Posted August 11, 2008 Share Posted August 11, 2008 I would tune for larger diameter pipe not just a gutted oem dp Link to comment Share on other sites More sharing options...
2005garnetGT Posted August 11, 2008 Share Posted August 11, 2008 I would tune for larger diameter pipe not just a gutted oem dp and you'd be wrong. yes, you should definitely tune for gutted OEMs Link to comment Share on other sites More sharing options...
05GT Guru Posted August 11, 2008 Share Posted August 11, 2008 You dont need a tune, but then whats the point of gutting the pipe, the pipe itself adds little hp the gain people see is because they tune the car. Most people goin stage 2 see very minor hp diffferences between a gutted oem and aftermarket dp. Its not until you start adding bigger turbos and things like that when you see a real difference between the oem gutted and aftermarket. Link to comment Share on other sites More sharing options...
nismoz Posted August 11, 2008 Author Share Posted August 11, 2008 I thought in order to go stage2, you need catless dp at least, which I want to accomplish by gutting the DP. But I want to gut the DP before receiving the Tactrix cable. So is it safe to run Stock everything with gutted DP? Link to comment Share on other sites More sharing options...
bradlgt21 Posted August 11, 2008 Share Posted August 11, 2008 You might get some check engine lights and flashing cruise. I mean your O2's are going to read that you got some dirty ish floating down the pipe. So I would recommend a tune. And technically the tune is stage 2. Stage 1 is a tune Stage 2 is a highflow downpipe and tune. So without the tune you are like at stage 0.5 Link to comment Share on other sites More sharing options...
nismoz Posted August 11, 2008 Author Share Posted August 11, 2008 I am going to use spark-defouler to eliminate CEL. So, is it safe to run catless DP without a tune? As I posted above, I will be gutting the DP before I have tool to flash the ECU. Link to comment Share on other sites More sharing options...
addison Posted August 11, 2008 Share Posted August 11, 2008 yea its totally safe its just a waste without tuning for it. are you going to to tune your car yourself? Link to comment Share on other sites More sharing options...
nismoz Posted August 11, 2008 Author Share Posted August 11, 2008 I won't be tuning the ECU myself cause I have almost have no idea about them to feel safe enough to do my own tuning. I will be getting some rom's from romraider website for either Stage 1 or 2. Would I notice anychanges by catless DP without any mod except smells? More sound or bit more torque on higher rpm? Link to comment Share on other sites More sharing options...
05GT Guru Posted August 13, 2008 Share Posted August 13, 2008 The turbo sounds a little louder, and i didnt notice a smell when i had just my dp gutted. I drove around for 2 days with the dp gutted adn no tune. Yes i threw and engine code but it just said i had a bad cat, which made sense since i didnt really have one lol. Link to comment Share on other sites More sharing options...
Infamous1 Posted August 13, 2008 Share Posted August 13, 2008 Moved to tuning.... Link to comment Share on other sites More sharing options...
dmp Posted August 13, 2008 Share Posted August 13, 2008 I'd be worried about boost spiking w/ a DP. I won't install my DP until I have a way to tune it, too. SOLD | '06 spec.B - VF52/AVO/740cc/Up/Down | 238awhp | 50-80mph 3.1 seconds. Link to comment Share on other sites More sharing options...
nismoz Posted August 14, 2008 Author Share Posted August 14, 2008 I haven't heard about this but how can catless DP cause boost spikes? Due to less backpressure? Link to comment Share on other sites More sharing options...
Infamous1 Posted August 14, 2008 Share Posted August 14, 2008 I haven't heard about this but how can catless DP cause boost spikes? Due to less backpressure? Yes! Link to comment Share on other sites More sharing options...
nismoz Posted August 15, 2008 Author Share Posted August 15, 2008 ^ Soon as Tactrix Cable arrives, I will be needing help from both you and Mickyeyed in RomRaider forum Link to comment Share on other sites More sharing options...
Infamous1 Posted August 15, 2008 Share Posted August 15, 2008 Yeah Mike doesn't venture over here too much anymore.... Link to comment Share on other sites More sharing options...
