Approaching 100k miles
NavyMan86
Well, my 05 Leggy is about to eclipse 100k miles and it's going to be time to do some serious refurbishing of parts and just a general tune-up; plus some pre-emptive "winterizing" for Connecticut's winters.
Things I've done:
Compression test (w/in 10lbs, low overall.. to be expected though)
brake pads and rotors (I've a thread in the brakes/suspension forum about some minor concerns I'm having)
New battery
New lightbulbs all around
What I'm doing:
Seafoam in the gas
I've a few ideas in mind:
Oil additives..? (I used Seafoam in my old truck and it didn't hurt anything, but with a turbo.. I'm not so sure)
Reset the ECU..?
Fluid flush everything (radiator, brakes, tranny)
A/C recharge
Alignment, re-balance tires (or just wait until I can afford new tires)
Spark plugs/wires
wiper blades
Air blasting the chassis to get a bunch of extra crud out
LCA bushings
Re-greasing the differentials
re-greasing everything.. come to think of it
Honestly thought about replacing all the wheel bearings just to save myself the trouble
Cobb AccessPort
I'm not exactly the most well-versed in these cars yet, still learning. Just wanna make sure this beauty see's 200k
  • 2 weeks later...
Things I've done:
brake pads and rotors (I've a thread in the brakes/suspension forum about some minor concerns I'm having) - worn out? why waste $$
New battery - was is original?
New lightbulbs all around - why waste $$?
What I'm doing:
Seafoam in the gas
Oil additives..? (I used Seafoam in my old truck and it didn't hurt anything, but with a turbo.. I'm not so sure) - just run rotella T6 and check the level often
Reset the ECU..? - why? does nothing?
Fluid flush everything (radiator, brakes, tranny) - flush brake fluid good idea at 100k, test coolant drain and fill if needed, tranny and rear end drain and fill are 60 or 80k service interval
A/C recharge - why?
Alignment, re-balance tires (or just wait until I can afford new tires) - why? do you have uneven wear? when was last alignment? any vibration? how much tread depth?
Spark plugs/wires - plugs are good idea at 100k, we don't have plug wires...
wiper blades - why? worn torn etc?
Air blasting the chassis to get a bunch of extra crud out - wut?
LCA bushings - why? torn?
Cobb AccessPort
