crisjp3 Posted January 18, 2017 Share Posted January 18, 2017 Hey all, My 00 LGT's rear diff bushings are shot. My questions are: 1) Has anyone used the whiteline Power Kit bushings. 2) Do they fit directly or does some modding have to be done? 3) I've read somewhere here of a quick way to do it yourself but the OP used OEM bushings. Can this also be done with the Whiteline assuming they fit? Thanks in advance! Link to comment Share on other sites More sharing options...
crisjp3 Posted January 18, 2017 Author Share Posted January 18, 2017 Any one have any Input? Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 18, 2017 Share Posted January 18, 2017 I've installed OEM bushings, Whiteline full poly bushings and have used the Whiteline poly inserts into the OEM bushings. Only thing really needed was sometimes the inserts don't quite fit into the OEM bushings so some grinding on the inserts is needed. I had a set of inserts in my 04 3.0 sedan and they worked great but I recently upgraded to a new subframe a new Whiteline bushings. Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 19, 2017 Share Posted January 19, 2017 The insert kit only works if you bushings are good. Whineline makes a whole bushing kit but they have to be pressed in. I've seen people use 3m window weld to make a poly bushing but you still need to drop the exhaust and other things Link to comment Share on other sites More sharing options...
