Danger Posted January 10, 2015 Share Posted January 10, 2015 Greetings all. Due to me being a clossal lazy ass my car has been on jack stands and has not been started in a year. I finally have it back together and am wanting to crank it up. Obviously at this point the gas is very old. I have tried siphoning the tank but cannot get a tube further down the filler neck than about a foot. I was wondering if I can top it up as best I can with fresh 93 octane from a gas can if I should be worried? Are there any fuel additives I can put in to also make this easier on the engine? I think it has a bit more than half a tank, unfortunately the battery is too dead right now for me to check, I just stuck my charger on it and am waiting. Any other words of advice for cranking it up? The oil is synthetic and doesn't have that many miles on it, should I start it up, let it get hot, and then change the oil? Or change the oil first? I also read something about pulling the ignition fuse and cranking the car to build oil pressure before starting it. How long should I crank it? 5-10 seconds? A couple of short bursts? Anything else I should be aware of? This is a Stage 2 tune, considering the gas situation I'm a little worried. Obviously I'm going to be reallllly gentle on the girl for that first tank of gas. Thanks all Link to comment Share on other sites More sharing options...
Underdog Posted January 10, 2015 Share Posted January 10, 2015 Personally I would drain the oil, change the filter, and refill with a priming tank (make your own for <$20) to get fresh oil throughout the engine before you even start it. Otherwise I would just check the fluids, make sure there are no nests in your air filter box, top off the gas, and fire it up. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Danger Posted January 10, 2015 Author Share Posted January 10, 2015 She's aliiiiivvveeee! I topped her up with 5 gallons of 93 along with a bottle of Seafoam. I discovered there is no ignition fuse, so I tried the trick of flooring the gas pedal while cranking to keep fuel from being sprayed. Cranked it a couple of times, crossed my fingers, and started it. She fired right up and ran and idled perfectly! Link to comment Share on other sites More sharing options...
