corlon Posted August 13, 2014 Share Posted August 13, 2014 just upgraded from a 1999 legacy l to a gt. doing plugs, wires, coil, air fliter, fuel filter, seafoam, etc and wondering what spark plug gap you guys are running on the 2.5 with the msd coil? I went with the ngk laser iridium plugs. Link to comment Share on other sites More sharing options...
twisty Posted August 14, 2014 Share Posted August 14, 2014 i think i gapped mine at .039 the first time, then regapped at .044 or close to it. runs well. i also am running the iridium plugs, but really they are a bit overkill on these cars. the platinums worked just fine. Link to comment Share on other sites More sharing options...
corlon Posted August 17, 2014 Author Share Posted August 17, 2014 I went with .047 to start with. I'll put some miles on and check them down the road. the plugs that were in there read .047 on cylinders 1 and 2, and .073 on 3 and 4. assuming all plugs were gapped the same when installed do you guys see the rear 2 cylinder burn up the tips of the spark plugs at all? do they run hotter / leaner? Link to comment Share on other sites More sharing options...
