RJS5689 Posted May 29, 2010 Share Posted May 29, 2010 I'm having a hard time deciding which LCA bushings to go with and where to find them. Nobody clearly calls their product an "LCA bushing". I keep seeing things like "anti-caster kits" and "anti-lift kit". Can someone point me in the right direction of products? Whiteline has what they call an "anti-lift kit". Are these the LCA bushings?http://www.rallitek.com/whankitkc.html Perrin lists what they call an "anti-lift kit" also.http://www.perrinperformance.com/products/list?category=8&model=10 SuperPro lays it right out there and calls their product "LCA bushings"http://www.fredbeansparts.com/index.php/suspension-parts/bushings-mounts/superpro-subaru-legacy-gt-lower-control-arm-bushings.htmlI know what offset bushings are, but what is the benefit of having one standard and one offset bushing compared to two offset bushings with the SuperPro kit. Can someone point me int the right direction. I'm looking for good, poly LCA bushings to replace my cracked factory ones. Link to comment Share on other sites More sharing options...
JonLGT Posted May 29, 2010 Share Posted May 29, 2010 Ive got the AVO non offset and I have nothing but good things to say. Link to comment Share on other sites More sharing options...
RJS5689 Posted May 29, 2010 Author Share Posted May 29, 2010 Ive got the AVO non offset and I have nothing but good things to say. I'm assuming the kit that you have is this one here: http://www.fredbeansparts.com/index.php/suspension-parts/bushings-mounts/avo-subaru-legacy-gt-lower-arm-bushing-kits.html This is actually one of the kits I'm looking at also. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 29, 2010 Share Posted May 29, 2010 Ive got the AVO non offset and I have nothing but good things to say. Ditto, and I also have the whiteline LCA forward bushings. I just did Parrin end links yesterday, see my post here. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
madcatz Posted June 1, 2010 Share Posted June 1, 2010 you didnt put a link in I just ordered the Offset AVO bits. from FBP. Cannot wait to get them in and installed....last effing part to come in then off to get corner balanced and aligned. -Travis Rob (rao) you're a fine gentleman, thanks I guess. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 1, 2010 Share Posted June 1, 2010 you didnt put a link in I just ordered the Offset AVO bits. from FBP. Cannot wait to get them in and installed....last effing part to come in then off to get corner balanced and aligned. sorry, http://www.tuningalliance.com/noCar.php I bought the end links from Mike. I'm sure Mike can get the bushings too. The whiteline LCA fronts came from FBP. You should have them replaced at the same time as the Front LCA rears. The arm needs to come off to put them any way's. So might as well do them at the same time. Surprised the guy's at FBP's didn't recommend that. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FredBeans Posted June 1, 2010 Share Posted June 1, 2010 We typically do recommend that, but depending on who you talk to and how high you put NVH on your list of concerns, we might not. OP, I have AVO offset (increased caster) bushings and I love them. The front suspension/steering feels much tighter and more precise with them versus stock bushings. When I bought my aluminum spec.b control arms they already had the AVOs pressed in, but when I need to replace them I will switch to Whiteline. I like that with the WL bushings you can adjust caster without multiple press operations... just loosen the gusset plate, make the adjustment and tighten it back up. Link to comment Share on other sites More sharing options...
AZP Installs Posted June 2, 2010 Share Posted June 2, 2010 I'm going to second the Whiteline LCA Bushings. Great setup. Oh and buy through our site (which leads to fred beans anyway ) or directly from FB... -mike Link to comment Share on other sites More sharing options...
berkshire40 Posted June 2, 2010 Share Posted June 2, 2010 I ordered the Whiteline bushings because of the adjustable caster (and the price). Can't wait to get all my suspension shit installed when they get here Mod list & photos _ Link to comment Share on other sites More sharing options...
eqt2010 Posted June 2, 2010 Share Posted June 2, 2010 Just had Whiteline LCA Bushing installed on my wagon(thanks to AZP installs) last week and it's great. I didn't feel any NVH. Link to comment Share on other sites More sharing options...
RJS5689 Posted June 4, 2010 Author Share Posted June 4, 2010 I went ahead and ordered the Perrin PSRS setup based on some LGT.com member's reviews. I'll let you guys know what I think of them once they come in. Link to comment Share on other sites More sharing options...
robinlsb Posted June 11, 2010 Share Posted June 11, 2010 Just had Whiteline LCA Bushing installed on my wagon(thanks to AZP installs) last week and it's great. I didn't feel any NVH. What did you set the caster too???????? And how long did it take (Ie labor hours)? "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
Max Capacity Posted June 17, 2010 Share Posted June 17, 2010 What did you set the caster too???????? And how long did it take (Ie labor hours)? Bump for Robin. I think my mechanic took about 4 hrs to do the job. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AZP Installs Posted June 17, 2010 Share Posted June 17, 2010 Takes us about 2.5hrs to do the LCA bushings. -mike Link to comment Share on other sites More sharing options...
Max Capacity Posted June 17, 2010 Share Posted June 17, 2010 Is that for both on the fronts, the rear and forward ones? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mustangendsley Posted June 17, 2010 Share Posted June 17, 2010 How do these press in? Do the press in 1 way or can you play around with them? Do you have to measure were the stock ones are at and then translate the new ones in that spot? Link to comment Share on other sites More sharing options...
AZP Installs Posted June 17, 2010 Share Posted June 17, 2010 Is that for both on the fronts, the rear and forward ones? That's just the rear of the front LCA ones. -mike Link to comment Share on other sites More sharing options...
mustangendsley Posted June 17, 2010 Share Posted June 17, 2010 ya the rear front lca. Link to comment Share on other sites More sharing options...
robinlsb Posted June 18, 2010 Share Posted June 18, 2010 Takes us about 2.5hrs to do the LCA bushings. -mike Thanks! Thats 100 bucks to my wrench and a couple of six packs of quality beer. (after he finishes the job:lol:) Again, I'll ask if you have done the big adjustable "donuts" and what caster you set. I am leaning toward max caster (which will be hard on the steering "box") but which will help the pavement "following" of GYDS3's. I think:lol: "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
GTTuner Posted June 18, 2010 Share Posted June 18, 2010 I ordered the Whiteline bushings because of the adjustable caster (and the price). Can't wait to get all my suspension shit installed when they get here The AVO's are OK but I prefer Whitelines because you have caster adjustability. Link to comment Share on other sites More sharing options...
robinlsb Posted June 18, 2010 Share Posted June 18, 2010 The AVO's are OK but I prefer Whitelines because you have caster adjustability. And you adjusted caster to?????????????????????????????? "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
AZP Installs Posted June 18, 2010 Share Posted June 18, 2010 The AVO unit's have a fixed adjustment on the caster. The Whitelines have Zero infinitely variable up to a certain point. Essentially you can rotate an offset insert from zero to max caster on the Whiteline units. -mike Link to comment Share on other sites More sharing options...
FredBeans Posted June 18, 2010 Share Posted June 18, 2010 The AVO unit's have a fixed adjustment on the caster. The Whitelines have Zero infinitely variable up to a certain point. Essentially you can rotate an offset insert from zero to max caster on the Whiteline units. -mike ... which is why I recommend the Whitelines to anyone who asks! Check out this post on our forum about choosing LCA bushings: http://forum.fredbeansparts.net/viewtopic.php?f=7&t=198 Link to comment Share on other sites More sharing options...
Bolksey85 Posted June 18, 2010 Share Posted June 18, 2010 ... which is why I recommend the Whitelines to anyone who asks! Check out this post on our forum about choosing LCA bushings: http://forum.fredbeansparts.net/viewtopic.php?f=7&t=198 Out of curiosity, how much do you guys get for installing the rears and an alignment? Link to comment Share on other sites More sharing options...
berkshire40 Posted June 19, 2010 Share Posted June 19, 2010 Out of curiosity, how much do you guys get for installing the rears and an alignment? Yeah, I gotta find someone to install mine. Everyone I ask thinks im crazy Mod list & photos _ Link to comment Share on other sites More sharing options...
