uptown4784 Posted October 18, 2014 Share Posted October 18, 2014 Yesterday, after work I decided to check my oil.. I had about one quart of oil..today as I arrived at work I checked the oil and shows that I don't have oil. The reason for this because I had just turned off the car? Link to comment Share on other sites More sharing options...
halwith Posted October 18, 2014 Share Posted October 18, 2014 Maybe you didn't push the dipstick all the way down Link to comment Share on other sites More sharing options...
GEE-OTTO Posted October 20, 2014 Share Posted October 20, 2014 The first reading was more accurate you still are about a qrt low BUT to be sure park on a level surface allow the car to sit (like the whole work day) then check it again. with a qrt low youre around 3 qrts or less in the pan so buy a qrt to have on hand to add when you check it. How often do you change you oil? Any apparent leaks? Link to comment Share on other sites More sharing options...
uptown4784 Posted October 21, 2014 Author Share Posted October 21, 2014 I change it every 3k..I will the most Ive gone without changing it probably 4500..I wrote my original statement wrong.. The second time the oil guy checked it.. and told me the car has no oil.. I am starting to think I need to let the car rest to check the oil in this car lol.. Link to comment Share on other sites More sharing options...
apexi Posted October 21, 2014 Share Posted October 21, 2014 I generally let the car sit at least 3 minutes. It's also worth noting the dipsticks on our cars are funky. One side of the dipstick will typically say one thing, like full, and the other side of the dipstick will say anywhere from like low to 1/2 full. I'm pretty sure this is because of the way the dipstick sits in the oil pan. I generally split the difference between what the back and front of the dipstick read, better safe than sorry. There have been times where I've checked the oil level and it'll say like 1/2 full, double checked, yup still half full, third check out of boredom? All of a sudden barely any oil on the dipstick. The dipsticks on our cars just stink, there's a few threads on the subject, here's one http://legacygt.com/forums/showthread.php/read-frickin-dipsticki-181504.html Link to comment Share on other sites More sharing options...
orndog Posted October 21, 2014 Share Posted October 21, 2014 I was staying out of this thread, but let's clear this up - your dipstick does not tell you that your oil is "half full" or "empty", it only measures down from full to low (depending on vehicle usually about 1.5 qts in America, your liters may vary). Yes, Subarus have notoriously frustrating oil readings. Link to comment Share on other sites More sharing options...
Yoda_One Posted October 28, 2014 Share Posted October 28, 2014 Or you vehicle was not on level ground Laughing at Oneself and with Other is good for the Soul Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 28, 2014 Share Posted October 28, 2014 ha I had the same issue today, just changed the oil on Saturday but then I checked today and it was at half, seems a bit more harder then the older Subaru's.. maybe it's the pan design? Link to comment Share on other sites More sharing options...
ttnio Posted October 28, 2014 Share Posted October 28, 2014 I was staying out of this thread, but let's clear this up - your dipstick does not tell you that your oil is "half full" or "empty", it only measures down from full to low (depending on vehicle usually about 1.5 qts in America, your liters may vary). Yes, Subarus have notoriously frustrating oil readings.[/quote Roger that.!!! Link to comment Share on other sites More sharing options...
