rayeve Posted June 8, 2015 Share Posted June 8, 2015 On a 2005 NA Legacy wagon, can a good DYI garage mechanic do the control arm and sway bar bushing replacements in the garage, or is there enough hydraulic press work involved that it will have to be a professional shop doing the work? Thanks. Link to comment Share on other sites More sharing options...
zzztech13 Posted June 9, 2015 Share Posted June 9, 2015 I did it myself in my driveway. Do some research, read some walkthroughs and know that it will take a little bitching. You can do it! You can take the LCS'a to a shop to have the bushings pressed out/in, or rent a tool. Link to comment Share on other sites More sharing options...
ras06LGT Posted June 9, 2015 Share Posted June 9, 2015 Sway bar bushings are very easy to do at home. Without a press the LCA bushings are going to be much more difficult. It might be possible, but I used a friend's press when doing mine so I didn't have to get creative. You can probably cut out the old ones pretty easily with a Sawzall or something (being careful not to damage the race on the control arm), but pressing the new ones in might be a bit too much for the bench vice method. Link to comment Share on other sites More sharing options...
whitetiger Posted June 9, 2015 Share Posted June 9, 2015 have a shop do the press work for the LCA bushings. Link to comment Share on other sites More sharing options...
